Old 02-16-2014, 07:48 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Once you get the old toilet out. You will find a flange mounted to the top of the tank. If it is in good shape and in the right position, the new unit will bolt right up.
The slots for the flange bolts should be a 9 and 3 o'clock for the new unit.
In thinking back. The hidden bolt on the left side, the plug I spoke of in my last post may be on the outside. It's just been too many years since I did the job.
TG Twinkie is online now   Reply With Quote
Old 03-22-2014, 05:36 PM   #16
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
I bought the adapter kit assuming I'd need it. It requires you to screw in 8 long screws to secure it it to the base. Isn't the holding tank right below the toilet?
I assume is I had to install the adapter the screws would penetrate through the platform and into the tank. I'm hoping someone will tell me that the platform my toilet sits on is elevated off of the tank? Anyone?
Dan
Dan S is offline   Reply With Quote
Old 03-23-2014, 03:41 PM   #17
Dan S's Avatar
1975 Argosy 26
Name:	ImageUploadedByAirstream Forums1395610668.992752.jpg
Here's what I have after the toilet is removed.
I must have to remove the old orange flange (screws and all) and install the one I have that will enable me to mount the toilet bolts at the 9 and 3 position.
Again, won't the new screws I install puncture my holding tank or would it be going through plywood?
Old 03-23-2014, 04:29 PM   #18
1977 Argosy 24
Milltown , Wisconsin
Don't use screws any longer then the plywood is thick. Don't risk putting a hole in your black water tank.
ventport is offline   Reply With Quote
Funny toilet vonprum Classic Motorhomes 3 02-11-2012 08:02 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
Thetford Style II toilet model 42059/replacing Lothlorian Sinks, Showers & Toilets 4 08-23-2011 05:07 PM
How do I find the correct replacement toilet? meredith Sinks, Showers & Toilets 1 07-15-2011 12:20 AM
Toilet over laminate? willbrackman Floor Finishes 0 07-11-2011 12:31 PM
