Old 12-19-2006, 07:59 PM   #1
76 Argosy 28' MH
john roeder's Avatar
1975 28' Argosy 28
Springfield , Ohio
New To Me
I was just wondering about the batteries. The mannual says that the rear battery is for the egine and the front is for the for the 12v parts of the coach. Is the front like a marine or deep cycle. Oh i have a 76 argosy 28. Thanks
john roeder is offline   Reply With Quote
Old 12-19-2006, 11:51 PM   #2
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
battery test
A simple way to find out is to disconnect a battery and see what works.I use a deep cycle battery for the inside coach.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 12-20-2006, 04:26 AM   #3
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Batteries
Hi John; The difference between batterries is, that RV Deep Cycle is designed differently and have different construction. RV/Marine battery is designed to work well while receiving a low rate charge giving you much longer use time under low amperage draw. In equal physical size batteries, the deep cycle will be considerably heavier having more plates. The plates are also retained at the bottom to withstand rough application in boats. Cranking battery in the same size will be much lighter and that is how you can identify them if the labels are missing. Starting battery will also be connected with much heavier battery cables than your coach battery. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-20-2006, 04:42 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Your house battery should be marine/deep cycle, and your cranking battery should be an automotive starting battery.
Group sizes that would probably be best in an unaltered motor home would be a group 74 starting battery, and a group 27 deep cycle battery.
Old 12-20-2006, 03:10 PM   #5
76 Argosy 28' MH
1975 28' Argosy 28
Springfield , Ohio
Thanks everyone, that helps a lot.
