Old 08-27-2009, 01:14 PM   #1
lascassas_camper
Apache_Camp's Avatar
1975 Argosy 24
Gatlinburg , Tennessee
New tires & rear sag gone!
Whew-hew, bit the bullet and bought 4 new, Bias Ply, 8 ply, D range matching trailer tires. $293.00 total including tax & mounting & balance.
***(I called around and got 3 places to match the prices on Ebay for their "Airstream" trailer tire, from Tucker Tire Co).
My trailer had mismatched radial and bias ply tires, it sure does sit alot better with the new tires. The trailer now sits straight and level.
Apache_Camp is offline   Reply With Quote
Old 09-01-2009, 08:02 AM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
A nice set of properly inflated tires dos make a big difference.
kennethowens is offline   Reply With Quote
Old 09-01-2009, 08:20 AM   #3
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Do new tires really help rear sag problem? Our tires are in ok shape, and we have some rear sag. Will replacing them improve the sag?
Thanks, Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 09-01-2009, 08:32 AM   #4
1975 Argosy 24
Malakoff , Texas
Rear sag - is a result of structural problems - not tires.
Old 09-01-2009, 08:37 AM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Rear end sag
Thanks, Mary
Mary, In your case I would say that tires won't help the rear end sag on your trailer. Apache Camp has tied two unrelated trailer conditions together. The thing his new tires cured was mis-matched tires and that could have given his 24' trailer the appearance of a droopy rear end. In your case the length of the trailer behind the axles and the frame condition/floor condition are most likely to cause rear end sag. Tires won't fix that issue. Get someone to check your frame members for failed welds, cracks, or rusted out metal. Reinforcing the frame by welding in braces is usually the fix. Of course you could build an entire new frame of aluminum and never have to worry again. But that to would cost more than a set of bias belted tires. Sorry to give you the bad news. I hope it keeps you from wasting money on tires that won't cure the sag. Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 09-01-2009, 09:16 AM   #6
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Not to pile on, but our '67 Overlander had some issues with the dreaded rear bath, floor rot. The "sag" wasn't bad, but there was simply no way of getting around fixing the frame. We decided on an admittedly more "extreme" approach by having a complete shell-off, frame restoration. We're also moving the bath to amidships and keep the weight on the rear of the coach modest. A solid new floor should help things along as well.
Congrats on getting good tires under you... and best of luck on the frame.
hampstead38 is offline   Reply With Quote
Old 09-01-2009, 02:03 PM   #7
Maryw164's Avatar
1972 31' Sovereign
That's what I thought. Our sag is not too bad, just a slight sag, if there is such a thing as a slight sag .
Mary
Happy Trailering !
Old 09-02-2009, 06:54 AM   #8
lascassas_camper
1975 Argosy 24
Tires & Sag
My sag was the result of 4 mismatched radial tires of different sizes, with the smaller radials being in the rear. This resulted in the trailer not sitting level and "squatting" in the rear.
I had 4 new 8 ply 700/15 Bias Ply Trailer tires installed. This is the correct style tires for this type of trailer. ID tag displays (5800#).
Radial tires can be used, but the sidewalls can give some and result in a lower stance and could be a safety issue if they are just car tires. Of course they do make radial trailer tires and/or radials that will work as trailer tires.
Rear sag question $bill Member Introductions 1 08-23-2009 11:28 PM
What causes rear sag on some airstreams? durans54 Repairing/Replacing Floor &/or Frame 4 12-02-2006 08:25 PM
Rear End Sag JimGolden Repairing/Replacing Floor &/or Frame 7 11-09-2005 09:20 AM
Rear Separation and Rear Sag on my '72 mello mike Axles 17 06-16-2005 01:58 PM
Rear sag- or no rear sag? aviontt Repairing/Replacing Floor &/or Frame 14 08-27-2003 05:38 PM
