Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 06-09-2016, 10:06 PM   #1
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
New tailights
I was not to keen with the old abs molded tail light housing. I repaired it but still didn't like it, so I installed these for a cleaner look. I really like them plus they are led!Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531581.705038.jpg
ID:	264132Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531596.752377.jpg
ID:	264133Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531609.518598.jpg
Matt
rugjenkins is offline   Reply With Quote
Old 06-09-2016, 10:21 PM   #2
1991 25' Excella
Stanfield , Oregon
Those look good, where'd you get them?
SpletKay06 is offline   Reply With Quote
Old 06-09-2016, 10:32 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Here's one place:
https://jet.com/search?term=Bargman%2084%20LED
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
I this great country!!!!
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 06-10-2016, 09:54 AM   #4
rugjenkins's Avatar
1975 Argosy 28
Led4rv
Matt
Old 06-12-2016, 01:14 AM   #5
1976 Argosy 26
diamond bar , California
I have the same lights but have been to chicken to cut holes. I have been bending the lights to see how they contort.
I noticed when I purchased mine, the prices were all over the place. But some had incandescent bulbs for reverse lights and others led.
How did you cut holes? Seal? Mount, any backing?
Your install looks great!
909kenu is offline   Reply With Quote
Old 06-12-2016, 01:58 PM   #6
rugjenkins's Avatar
1975 Argosy 28
Not finished yet, I cut the holes with a set of tin snips. They conform to the side angle pretty good. The corners on the sides are not flush but once caulked with black sikaflex 221 it will look awesome! I'm on vac now but will finish the lights next week. I'll post pics. Led on turn and stop with incandesce in the middle
Matt
Old 06-22-2016, 12:40 AM   #7
1976 Argosy 26
You and your thread gave me the courage. The cut is a bit to the side more that yours because of the existing grommet. I'm going to connect the wires with 4 pin trailer plugs for ease of removal. I'm planning to temporarily paint with spray can but repainting entire trailer in the future, so the light will come out a few times.
Old 06-22-2016, 02:37 AM   #8
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Looks great!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-23-2016, 12:45 PM   #9
rugjenkins's Avatar
1975 Argosy 28
Actually you placed yours in the same spot as mine. It looks great! Your doing a great job
Matt
Old 06-23-2016, 12:57 PM   #10
JimGolden's Avatar
1977 31' Excella 500
Looks good!
Looks great!
My plastic housings were toast as well.
I made these housings for mine. Used all 5.5" diameter LED lights from superbrightleds.com Housings are .040" thick 6061 aluminum and riveted with AN headed rivets.
After I made these and installed them, I discovered a place that had ones similar to the OEM's that I replaced. Ah well, mine are unique. I went for a "Corvette Look" with the three horizontal lights on each side, but it came out looking a bit 1930's German Industrial. I like 'em though
ID:	265009   Click image for larger version
- Jim
JimGolden is offline   Reply With Quote
Old 06-25-2016, 09:45 AM   #11
BentMetal's Avatar
1972 Argosy 26
Alamogordo , New Mexico
I have the same lights!
We installed these about a year ago. They are great!
Name:	tail lights on argosy2.png
BentMetal is offline   Reply With Quote
1964 Bambi II tailights 55AS Airstream Classifieds 0 02-09-2015 02:50 PM
Tailights only partially work adwriter73 Lights - Interior & Exterior 26 08-17-2011 07:44 PM
LED Tailights SilverHoot Lights - Interior & Exterior 13 03-31-2011 12:18 AM
Cast Aluminum Tailights ROBERTSUNRUS Lights - Interior & Exterior 8 01-28-2007 04:45 PM
Tailights Marc Marenco 1974 - 1979 Sovereign 17 07-13-2005 06:42 PM
