Old 06-03-2009, 07:30 PM   #21
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
A big 10-4 on the ice box-just had a new compressor put in my 77 6.0 and a few mins does it!
vcu70 is offline   Reply With Quote
Old 06-03-2009, 08:12 PM   #22
Graham , North Carolina
very nice and you can be proud
take care
jerrypeterma is offline   Reply With Quote
Old 06-03-2009, 08:13 PM   #23
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
New Paint Photos
Greetings chuckmac!
Originally Posted by chuckmac View Post
Are your hubcaps origanal? I have a 76 24ft and have the same hubcaps but wanted to know if they were OEM. Mine are the same as yours.
Yes, those are the correct full wheel covers. The base would have been "baby moon" style hubcaps, the most costly option would have been the aluminum wheels, and the intermediate option would have been the wheel covers. The Argosy full wheel covers were basically Airstream wheel covers of the same period without the blue center emblem. During a portion of the model run, some of the Argosy wheel covers had a tan paint applied to the center emblems of the wheel covers.
Kevin
Kevin D. Allen
AIR #827
Old 06-03-2009, 10:24 PM   #24
1992 34' Excella
hinton , alberta
thanks Kevin. NOW I have to find one more so I have a set.
Thanks for the info
chuck
chuckmac is offline   Reply With Quote
Old 06-04-2009, 07:13 AM   #25
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Rivet_lines
nick6930 - Yes I did use stripper on the rivet lines. Using a Gel stripper,
I put masking tape about 1" on both sides of the rivet line the applied
a large amount of stripper. When it looked like the stuff had worked, and
while it was still very moist, I took a drill with a wire bush attachment and
slowly went along the rivet line. It slings off and makes a mess. But 15 to
20 feet of "Beautifully-Clean-Shiney" rivet heads emerge in less than 30 minutes. Those rivet heads really do not like sandpaper or a whole lot of
aggrivation of any kind. When I was doing the prep. work...I began to realize why there is the promotional rating system here all the way up
to "RivetMaster". I just have earned 2 rivets so far...and not sure how I did that....I am playing....anyone know how a fellow gets a "Promotion around this place".......not that I think I deserve one...but I was curious.
kennethowens is offline   Reply With Quote
Old 06-04-2009, 07:23 AM   #26
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
Absolutely beautiful!
biggoofball is offline   Reply With Quote
Old 06-04-2009, 07:31 AM   #27
1975 Argosy 24
Malakoff , Texas
biggoofball - Thank you. One more thing...I tried looking at your
1972 Argosy 22 (looking for a new home)...the school where I work
has it blocked...anyway, I could talk you into posting one or two photos
in here so I could take a look. It may be in here...but I don't know where.
Old 06-04-2009, 09:53 AM   #28
Usually Sleepy
Images: 14
Sure:
Previous owner painted it a GM silver/bronze color from the 90's. Interior is nearly mint and original except for this sweet control panel that the previous owner built.
I just looked for my classified ad so you could see more photos, it must have run out so here's one shot of the interior.
I'll email you photos if you want. send me a pm.
/thread hijack over.
Old 06-06-2009, 04:22 PM   #29
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
OK, I have another question and thought I would ask it here. Have you ever thought about leaving it bare aluminum and just painting the end caps. I went crazy today and have been stripping everything and the metal looks great. I thought I would find bondo everywhere. I am thinking about just polishing her up and paint the end caps and maybe the line down the center top to cover those rivet lines on top. If nothing else it will buy me time to learn how to paint well. But is this a bad idea will it have major leak issues?
I may need to start a new thread but thought I would ask here first.
Sorry to hijack.
Thanks Nick
nick6930 is offline   Reply With Quote
Old 06-07-2009, 12:04 AM   #30
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
New Paint Photos
Greetings Nick!
An Argosy that is stripped and polished is no more likely to leak than a similar Airstream. There are several polished Argosy travel trailers running around. The silver painted end caps don't stand out as much as you might think. You will still need to seal all of the seams as part of the process just as if you were painting the coach as the stripper also removes the seam sealers with the paint.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 06-07-2009, 12:09 PM   #31
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
She looks great! Keep up the good work.
76sovereign is offline   Reply With Quote
Old 06-16-2009, 07:49 PM   #32
1976 24' Argosy 24
Milford , New Jersey
Kenneth, can you share some paint info with me. Looks great I must say. What type of paint did you use and is it a single stage or a base coat/ clearcoat system. I'm real close to getting our Arg. painted and this info would be helpfull. Thanks George
Gkiesel is offline   Reply With Quote
Old 06-25-2009, 04:17 PM   #33
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
Very Nice! You did a really good job.....
Alwhisman is offline   Reply With Quote
Old 06-26-2009, 09:16 AM   #34
1973 Argosy 26
chouteau , Oklahoma
Smile thanks for the pics & info
We just purchased our 1973 26 ft & it lookes much like yours did in the begining .....the wife was less than pleased when I brought it home .....but thanks to your pics & a little cleaning, both her & the trailer are doing much better.....thanks
wranglerguy is offline   Reply With Quote
Old 07-09-2009, 04:08 PM   #35
2Alaska's Avatar
1977 Argosy 24
Hudson , New Hampshire
Send a message via AIM to 2Alaska
New Paint!
Check out the new paint job on the Argosy. She's even more beautiful than before! I can't wait to take her out.
~2Alaska
ID:	83714   Click image for larger version
2Alaska is offline   Reply With Quote
Old 07-10-2009, 08:25 AM   #36
nick6930's Avatar
1979 Argosy 27
1953 25' Cruiser
Wow great job, she looks awesome.
Old 07-10-2009, 08:33 AM   #37
redeagle313's Avatar
NE , Indiana
Ditto! Nice!
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
redeagle313 is offline   Reply With Quote
Old 07-10-2009, 10:24 AM   #38
1976 31' Sovereign
ozark , Missouri
NIce job! Love it!
~2Alaska
Old 06-07-2010, 07:26 PM   #39
1978 31' Excella 500
SOUTH ANHERST , Ohio
Love the paint job , i have a 1975 26 ft and will be in need of a painting , what number will i be looking at , did you also get a clear coat finish , it sure looks like it , nice job.
Gosman is offline   Reply With Quote
Old 02-12-2019, 08:55 AM   #40
1977 Argosy 20
Olive Branch , Mississippi
Baked on paint
I will be needing to paint my emblems as well. Please share how your wife baked the paint onto the emblems. What type of paint and how long did she bake it at what temps?
Argo20 is offline   Reply With Quote
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
Photos hampstead38 1965 - 1969 Overlander 2 08-18-2008 08:19 PM
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? scooterpie Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
