Old 04-03-2008, 07:51 AM   #1
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
New Argosy owners!
We picked up our 76 Argosy at Bat Cave on Monday, and after a few issues with it (the hot water tank leaked, but will be replaced) and we had to bypass it so we would have water, the furnace needs serviced, but we found a little ceramic heater that works just fine, and the refrigerator wouldn't work on electricity but works great on propane; we are really enjoying it. We haven't hauled it home to Missouri yet, still at a KOA in North Carolina, but towing it out of those switchbacks and hairpin curves from Bat Cave was no problem with our Ford f 150.The interior is pretty good, not too much to be done there, but she does need a new paint job and a bit of other exterior work. Everything else works fine, no leaks so far detected. Kind of a funky smell coming from the oven but haven't really investigated to see if it is the pilot light not lit or a dead mouse somewhere, or just needs a good cleaning. That will wait until we get home where the shop vac and all my cleaning stuff are.
Isadora is offline   Reply With Quote
Old 04-03-2008, 08:10 AM   #2
B&D
B&D's Avatar
1975 31' Sovereign
1955 22' Safari
Columbus , Indiana
Hope you enjoy. Keep us posted and pics are always wanted.
B&D Indiana
B&D is offline   Reply With Quote
Old 04-03-2008, 08:15 AM   #3
LookingThroughALens
aturner4u's Avatar
1976 Argosy 24
Marietta , Georgia
Images: 20
Welcome to the forum and to Argosy ownership. Best wishes as you finish your journey home.
In nature, light creates the color. In the picture, color creates the light. --- Hans Hofmann
aturner4u is offline   Reply With Quote
Old 04-03-2008, 08:33 AM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Best of luck with the Argosy trailer. Krylon Ivory gloss in a spray can is a good touch up choice for a paint fix. Make sure the oven control valve is turned to the "pilot off position", not just the off position. Off only is actually "Pilot On" and means propane is entering the oven whether the pilot is lit or not.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-03-2008, 05:33 PM   #5
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
I will post pictures as soon as I get them downloaded from the camera, at least I will try to. thanks, will check the oven control valve. I don't think the pilot is lit. We start out in the morning for home, can't wait to get there. It's been cold and rainy in NC!
Old 04-03-2008, 05:50 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Congratulations on your new trailer.
Did you go on up over the mountain to Asheville, or did you come back out, and up the Interstate?
Old 04-03-2008, 06:01 PM   #7
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Congratulations on picking up your Argosy. Making this trailer your own is going to be fun. Bob and I had such a good time working on our Argosy that we just can't find it in our hearts to sell it. We have the Sovereign now, but the Twink was our first project and still our first love. Let us see those pictures.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 04-03-2008, 06:04 PM   #8
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
So far the only place we've towed it is from Bat Cave to Swannanoa to this KOA east of Asheville, but when we came down here we came across the mountains on 40 and will probably go back the same way, it looks like the best route.
Old 04-03-2008, 06:10 PM   #9
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
so far we're loving the Argosy, with the front dinette and the back double bed, it is just the right setup for us. Can't wait until we get home and we can really start working on it in ernest, tweaking everything! by the way, Bob and Judy, I love the way you replaced the tambour under the sink, we are going to have to do something with it because it is in really bad shape.Building doors and using the tambour in the centers is an option I like.
Old 04-04-2008, 07:22 PM   #10
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Well we are more than halfway home with our Argody, it is making the trip with few problems, the main one being that in the driving rain we were going thru, a little water leaked under the front window but I think that should be easily fixed once we get home. I think the weather stripping is gone. The only other problem we had this morning was when we found the water tank was full, and overflowing. It appears a check valve, or the water pump, one or the other, malfunctioned somehow and the city water that we were hooked to, flowed into the tank. An RV repairman who just happened to be in the campground where we stayed said he thought the water pump had a crack in it from not being properly winterized. So it looks like that will have to be replaced. Needless to say we are dry camping tonight. Except for the fact that it rained all day, I guess you couldn't actually say it was dry. the good news, it appears that nothing else leaked.
Old 04-04-2008, 07:54 PM   #11
Well Preserved
1993 21' Sovereign
Generally, the check valve in in the water pump. If you replace the pump, you will be replacing the check valve at the same time.
Old 04-04-2008, 08:05 PM   #12
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Well, maybe the check valve, but since we had quite a puddle under the pump, the repairman thought it might be the pump. I think he told Jim how to test for it to see if the pump itself was leaking.
Old 04-04-2008, 10:02 PM   #13
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
The rain is moving away from you and tomorrow should be a good day for tracking down your problems. Water pumps are not expensive, so if that's your problem it should be an easy fix. The Tambour door problems plagued us for about 2 years until we gave up and replaced all the horizontal ones. There was the big one under the kitchen sink and the little one under the bathroom sink. It's a relief to just be able to open a door and access more storage room. Maybe it's not "original"; however, it makes life easier for us and that's what really matters. I'm looking forward to seeing pictures when you get home. That's a long trip with just a couple of problems. Our Argosy lost it's brakes and lights on the trip home from El Paso, Texas. Actually the brakes did sort of work, they locked up every time you tried to back the trailer. The A/C stopped working on our first camping trip, but after almost 30 years of service it needed to be retired. Things will happen, but the Argosy and you will probably make it another 30 years.
Old 04-04-2008, 11:41 PM   #14
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Congratulations!
Hi Isadora,
Check all the connections on the electric side. The fridge in my ’67 Trade Wind quit working, but when I looked at the thermostat below the unit behind the drop-down cover (it’s a 1967, after all) the wire lugs were corroded. After cleaning, it worked perfectly again. Still.
Vaughan
First Time Argosy Owners Family Camp Member Introductions 26 04-16-2008 07:01 PM
New (old) Argosy Owners Grey Ghost Member Introductions 7 03-16-2008 08:31 PM
newbie argosy owners basecmp Member Introductions 6 03-11-2008 09:28 AM
Any Argosy Owners near Little Rock tkchase All Argosy Trailers 1 04-04-2006 05:18 PM
Argosy owners unite !! ericandterry All Argosy Trailers 48 05-13-2004 05:12 PM
