Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 05-18-2014, 09:14 PM   #1
1976 Argosy 26
Klamath Falls , Oregon
Need to get on the roof!
I'm used to rectangular trailers with ladders... Two questions here.
(1) What do I need to know about getting on the roof of a 1977 Argosy 26? Do's and don'ts?!
(2) My air conditioner blows cool air all day, but not cold air. I'd like to troubleshoot. That probably means I need to get on the roof. Thoughts on what to look for, assuming I figure out question (1)?
Thanks so much! Our maiden voyage with the kiddos in the "new" trailer is this weekend...
Jeff
sledf15 is offline   Reply With Quote
Old 05-18-2014, 09:40 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Don't ever step on the formed end caps. In theory, you can walk around on the rest of it without worry, but I try to keep my weight on the rivet lines. To get up there, lean your ladder against the awning, and up you go. As for troubleshooting your AC goes, about all you can do is confirm your fan blades are not damaged, and that the condenser coil is not stopped up with birds' nests or wasp nests. Beyond that, you will need special equipment and knowledge. If this is the original AC, then it might be time to make a decision about replacing it altogether or attempting some kind of rebuild.
Old 05-18-2014, 09:41 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
There's a picture of my padded ladder in this thread... http://www.airforums.com/forums/f448...on-118117.html
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
drboyd is offline   Reply With Quote
Old 05-18-2014, 09:55 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The original Armstrong AC is repairable. The new ones are designed to be replaced.
Your typical RV shop is not the place to have the Armstrong unit checked out. Heating and Air Conditioning Shops have the skills required.
You may have to remove it and take it to them.
That would be the major consideration in my opinion.
Old 05-19-2014, 09:55 PM   #5
1976 Argosy 26
Thanks for the "walk on the rivet lines" and the picture of the padded ladder! This is a "newer" AC unit--I think 1990's. Dometic duotherm... Someone at work said "just get it charged with freon". I hope it's that easy. Does that generate any more info?
We've been cleaning and testing things out. Packing the trailer tomorrow. On the road Thursday. Excited! Will have to post pictures, even though it will only be cool to us.
Old 05-21-2014, 09:14 AM   #6
Belegedhel's Avatar
Houston , Texas
Well, it is good news, in my opinion, that you have a "modern" AC unit. You should get more help at a typical rv repair place than you might with the original AC unit. Did you pull off the shroud and take a visual?
Old 05-25-2014, 06:52 PM   #7
1976 Argosy 26
First trip, success!
Haven't looked at AC unit yet, but first trip went great. Here are a few pictures. Next question... how to pack/re-pack the wheel bearings...
ID:	212816   Click image for larger version
ID:	212818   Click image for larger version
Old 05-27-2014, 10:23 AM   #8
Belegedhel's Avatar
Houston , Texas
You might want to seriously investigate a rock guard for your front panoramic (wing) windows. These windows are probably more likely to catch a stone than the center window, and they are hard to come by, and very expensive to replace.
good luck!
Old 05-27-2014, 03:38 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
How to get on AS roof?
I may have tried a few tricks to get on the roof.
http://www.airforums.com/forums/f478...oof-66345.html
This setup is how I did all the top work including replacing the air conditioner and all 3 roof vents.
Click on the link to see a picture of the Sioux River falls near my home.
https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
Eastern South Dakota is very pretty with hills, rivers, and trees.
Splitrock is offline   Reply With Quote
Old 06-04-2014, 09:14 PM   #10
BentMetal's Avatar
1972 Argosy 26
Alamogordo , New Mexico
I was just up on my roof walking on rivet lines. I also laid some boards across the rivets on top. I sure like the scaffold Splitrock did. It will provide more stability.. not much room to move around on top of a curved Argosy.
BentMetal is offline   Reply With Quote
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
