Old 06-23-2016, 02:54 PM   #1
75ArgosyRob's Avatar
1975 Argosy 26
Ripley , West Virginia
mystery wires
[/URL][/IMG]
(see pic)
the orange wire near the floor.... Water pump maybe?
any ideas
75ArgosyRob is offline   Reply With Quote
Old 06-23-2016, 02:58 PM   #2
1975 Argosy 26
mystery wire 1
black wire in overhead roll door front storage? any ideas what it is for?
(see pic)
[/URL][/IMG]
Old 06-23-2016, 04:11 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Is the wire hot, ~12 volts DC?
My Tradewind had a similar grommet and black wire coming out into the front roof locker. The wiring diagram indicated it was for the optional radio and is connected to the 12 volt charge line. Found the antenna wire behind the storage box. Needed to add ground and speaker wiring when I put a radio in.
Tom
AirForums # 2806
WBCCI / VAC # 6411
TAC IL-11
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-23-2016, 04:14 PM   #4
1975 Argosy 26
I'm awaiting a new converter and fuse block for 12v. i shall check it then.
Thanks for the reply.
Old 06-23-2016, 11:01 PM   #5
1976 Argosy 26
diamond bar , California
I have a 76 26' Argosy. Yes and Yes. Pump line hot when pump switch is on. I have a radio in that compartment also.
I'm the 3rd owner so I'm not sure who installed the ground wires but they are there along with those wires.
New converter and fuse box, nice. What are you doing for battery?
909kenu is offline   Reply With Quote
Old 06-24-2016, 06:30 AM   #6
1975 Argosy 26
Thanks! I have no water tank up front (po removed it). But the pump was lying (loosely) under the twin bed.
So...(silly question)... Is the antenna used for radio, tv or both?
I'm installing a boondocker 45amp and 9 circuit fuse block from best converter.com. As for battery, my local auto parts plus store sells Harris batteries. So prob a deep cycle marine around $100. Any experience with Harris batteries? Locally also have advance auto, auto zone, Walmart.
Currently have no battery box, planning on building one. Prob wood enclosure, maybe slide out tray at access door...maybe. Mounting converter to top or side of battery box.
Old 06-24-2016, 06:40 AM   #7
1975 Argosy 26
Kinda motley looking, but it'll shape up.
[/URL][/IMG]
Old 06-24-2016, 11:39 AM   #8
fluxcap's Avatar
1977 Argosy Minuet 6.0 Metre
Newnan , Georgia
Well....
Well since it looks like y'all have figured out what Rob's mystery wires were for, any guesses at these wires? This is an old picture. I have since cleaned up all the wiring, but these two could not be traced to anything. It's a 1977 20' minuet.
I'm asking about the orange and white wires.
Everything electrical is working, so I guess they either went to something that has been removed, or was never installed to begin with.
Also have another bunch of wires I'll post in a second.
fluxcap is offline   Reply With Quote
Old 06-24-2016, 11:47 AM   #9
fluxcap's Avatar
Newnan , Georgia
Here are the other wires. These are in the overhead storage area over the sink and stove countertop. I have a few screw holes that look like something may have been mounted under the storage cabinet, but there aren't any holes big enough for these wires to have passed through. Pre-run speaker wires maybe? If so, where are the other ends? This is a minuet, so I don't have the usual overhead cabinet on the front endcap where most stereos where installed.
Old 06-24-2016, 07:35 PM   #10
1976 Argosy 26
I'm at the same crossroad. The existing battery box was leaking, the exterior door is vented so water gets in there. I did go to Costco and purchased (2) 6v but now I need to build a box or vent a sealed box to the outside. Many have suggested AGM batteries to mitigate the venting issue. I'm thinking that was the way to go. But for $83 per 6v battery how can you go wrong??? They may not be the best but I'll try them out.
Old 06-24-2016, 09:28 PM   #11
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Those look like speaker wires. If your trailer has no factory installed speakers then the other end are taped to the inside of the outer skin. If you can find a service for your trailer (I had to order one from Airstream) you will find the info in it on where to cut into the interior wall to find the wires. Did on mine and was within a couple of inches of the wires. Use a coat hanger bend the end and fish around to find them.
thehandyman is offline   Reply With Quote
Old 06-25-2016, 07:02 AM   #12
fluxcap's Avatar
Newnan , Georgia
Thanks handyman! I doubt we'll install anything, just been curious as to what they were for.
Blue and white stripe mystery wires ckweaver Electrical - Systems, Generators, Batteries & Solar 0 09-29-2010 05:56 PM
Mystery wires behind stereo Westfalia Audio, Video & TV 30 08-11-2008 04:37 PM
need help on mystery wires twiggy137 Electrical - Systems, Generators, Batteries & Solar 4 05-27-2008 11:45 AM
Mystery Wires aeriqua Electrical - Systems, Generators, Batteries & Solar 2 10-03-2007 05:28 AM
Mystery Wires sfixx Electrical - Systems, Generators, Batteries & Solar 10 03-21-2005 03:54 PM
