Old 04-27-2012, 07:47 PM   #1
Bootsinister's Avatar
1975 Argosy 22
Murray , UT
Mystery Mounting Points ??? Any Ideas
Hello All
I have a question I hope you all can help with ?? These mounts appear on top of our recently purchased Argosy 22 and I am curious if any one has an idea?? Solar array ?? Also any idea where to get replacement parts ( main vent ) for duo therm ??
THANK YOU ALL
bOot
ID:	156922   Click image for larger version
Bootsinister is offline   Reply With Quote
Old 04-27-2012, 08:08 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
The device on the roof in the left portion of your photo appears to be one of your tank vents. This is one of the areas that must be monitored for leaks on our coaches. There is a hidden gasket inside of the shroud that seals the vent pipe to the roof and that gasket needs to be replaced about every third year. The device toward the front also looks like it may be a plumbing vent as well (possibly for the galley sink?).
The device on the side of your coach is not familiar to me. My speculation is that it may have been an attaching point for an aftermarket exterior table or something of that nature. A second possibility might be that it was an attachment point for a tire shield that was installed to protect the tires when the coach was in storage.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 04-28-2012, 05:53 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
When you say "main vent" for the AC do you mean the ceiling assembly or the exterior shroud or..?
Here is a site with some parts diagrams:
31072069 Parts
PPL also sells the ceiling assembly:
Dometic Duo Therm Air Condtioners on Sale - PPL Motor Homes
Old 04-28-2012, 06:19 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Vent pipe gaskets and screens for the vent covers that Kevin mentions above:
Airstream Special : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Old 04-28-2012, 06:32 AM   #5
Gainesville , Florida
Awning mounts? jim
Old 04-28-2012, 01:32 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
I don't see any top mounts. I see two sewer vents.
