Old 01-19-2007, 06:21 AM   #29
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
I am with Terry check your Ref. drain.
Phil Gobie is offline   Reply With Quote
Old 01-19-2007, 07:13 AM   #30
galfoman's Avatar
2002 19' Bambi
Dorchester , Massachusetts
Ok I will check it today,
But it has not been running in 10 days or more.
Would it still have water in it?
G
galfoman is offline   Reply With Quote
Old 04-03-2007, 10:36 AM   #31
sierrajb's Avatar
Arlington , Texas
Mystery Solved!
Hate to return to the original discussion so quickly, but I figured someone out there may wonder if I ever discovered the cause for this "mysterious wet spot." The answer is YES!
Without going into all the detail, let me just say I had MULTIPLE, undetectable water leaks from swollen copper pipes that I had to replace every copper line with PEX. The mysterious wet spot was a result of one of these "hidden" leaks in the copper line from my hot water heater that ran under my furnace duct. This was the source of the original "wet spot." I believe someone in this thread called the leak a "traveler" or something like that. Whoever you are, you were right.
So, with 98% of all copper replaced with PEX (still need to pipe in the bath/shower), we're in the dry. We had to chunk the soggy carpet padding and berber carpet. Next...new floor covering.
....Okay, guys, you can resume your discussion, now.
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Wet floor, finding & stopping leak Joseph O. Smith Repairing/Replacing Floor &/or Frame 4 03-24-2003 10:17 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
