Old 11-28-2006, 02:34 PM   #15
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Has this happened more than once?
Pop Rivet is offline   Reply With Quote
Old 11-28-2006, 02:58 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by sierrajb
How sure are you that no plumbing is under the floor in the middle? Do the pipes to the gray tank run alongside the streetside, too? I plan on dropping the bottom cover in a few days to take a look-see.
Airstreams traditionally have water systems above the floor until just over the tanks -- and the only below floor tank in a stock Argosy starting with 1974 would be the gray -- well aft. Your freshwater tank is under the front windows? The water pump is roadside next to that tank and you can probably see the metal shield protecting the copper pipe at the wall between your couch & sink cabinet. All fresh water in an Argosy is above the floor runs roadside under cabinets back to the bathroom area (and roadside twin bed if applicable). You should be able to see them if you can look under cabinets at the interior layout of the hot water heater, then again back at the roadside rear corner near the univolt. This is the only water that would be pressurized. I'd have to jog my memory about the location of the gravity drained gray water pipe...
5 meter Langford Nahanni
Old 11-28-2006, 03:29 PM   #17
Pop Rivet's Avatar
Altoona , Georgia
I suspect you have a traveler. Do you have a sub floor? It's possible you have a small leak in one of the expected places and if you have a sub floor, the water is traveling beween the floors to a low spot and then surfaces at the location you have noticed, Also, if the rug is an arcrilic material, the surface may not feel wet has that material will not absorb the mositure. The leak may be intermitent and it may be very small. This is getting interesting
Old 11-28-2006, 04:47 PM   #18
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
My Argosy has the tray in the fridge to catch the condensate and we quite often forget to empty it before moving and end up with a puddle in the middle of the floor. Ours has a vinal floor so it does not hurt anything and it was a mystery till we traced it to the fridge.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-28-2006, 08:52 PM   #19
sierrajb's Avatar
Arlington , Texas
Insideout & Rickandsandi,
No water puddles within miles of the wet spot. True, the bottom pan is not perfect, but there's NO perforations anywhere that water could splash up to the floor.
Terry (overlander63),
I didn't have the fridge on until I got to the campsite. I found the wet spot long before condensation had a chance to form. In fact, the fridge was still plugged in at the campsite & plenty cold.
David Alan,
As far as I know, this was the first time it's happened, but then again, it was the first time I've ever had it out. I've only had it for 2 weeks. PO said nothing about it...but then, she probably wasn't as observant as I.
Canoe Stream,
Your description of my water system is exact. Like you, I'm not sure if the gray water drain pipe takes a turn under the floor at that mid point. My hunch is that if there IS a drain pipe in that area, I've got a leak that's squirting gray water upward, hitting the bottom of the floor.
David Alan,
Not exactly sure what you mean by a "sub floor." My limited understanding tells me I have only ONE floor, and that's a wooden floor.
Shacksman,
At this point, I really WISH it was as simply as a condensation tray that spilled. However, I'm convinced it is not that. That was a good possibility, until I ruled it out.
My latest update: I've pulled the berber carpet and the padding all the way back, enough to see all the wood between the fridge and the oven. When first discovered, the floor was DRY from the fridge to the wet spot and from the oven to the wet spot. I tell you, this wet spot seems to have appeared out of nowhere. The wet spot is now GONE and the carpet pad is now DRY. I may hook up to the garden hose, run the water in the kitchen sink, and try to reproduce the wet spot. However, it's due to freeze any day now, so that little test may have to wait. I'll let you all know what I discover. Keep those brain waves flowing! Thanks for your input.
Airstreams are like a box of chocolates....
sierrajb is offline   Reply With Quote
Old 11-28-2006, 09:09 PM   #20
The grey line is gravity drained and not pressurized -- so could not squirt up. Dry weather and no A/C use -- I wonder if it couldn't have been an unobserved but one-time event.
No, there's no subfloor situation if you have the original ply under a rug. (What color?!?! )
Any oily spot could be persistent but wouldn't dry as readily. A real puzzle... I would think that an infrequent drip from above could make the rug seem dry but keep the area under the rug damp -- but there was no rain and no A/C.
sierrajb? Is this a new unit for you? Congrats if that is in order!
Old 11-28-2006, 09:44 PM   #21
sierrajb's Avatar
Arlington , Texas
Yes, Canoe Stream...this is a new one for us. A year ago we bought a 67 Overlander, but finances forced us to sell. Never got the aluminum out of our blood, and found this one 2 weeks ago in the classifieds of this forum. This one's better for our family and is definitely a keeper. Everyone's been so much help!
Old 11-29-2006, 08:55 AM   #22
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
This is a better mystery/detective story than the novel I'm trying to read right now. I have to check in frequently to get the next chapter.
I must admit, it's looking a lot more like the puppy versus the butler or the much younger wife by a long shot. Where the heck is Columbo or Perry when you need them?
It will be very interesting to see if the wet spot returns or was a one time event.
Barry
safari57 is offline   Reply With Quote
Old 11-29-2006, 09:48 AM   #23
sierrajb -- a little off topic but some points relevant to a new Argosy owner.
The gasket on your water fill door is probably hardened and allows rainwater down the exterior of the trailer to enter the water tank.
The gasket on the battery compartment door is truly on the sides only, with none at the top so hydrogen can vent. Since moisture can get in make very sure that the aluminum bottom pan is very well caulked with Sikaflex or Vulkem to the inside black plastic shell -- this would be a very easy place to get floor rot. The old battery had dropped through and was resting in the banana wrap on mine. The plastic shell is fragile and would be hard to replace, so be careful.
Old 11-29-2006, 12:16 PM   #24
sierrajb's Avatar
Arlington , Texas
Safari57,
Is that a gorgeous 57 Nomad you have in your picture? Love it! I'll keep you and the others posted on what I find in regard to this "mystery wet spot." Lots of helpful (some humorous) ideas concerning the source of the moisture.
Canoe Stream,
You must be reading my Argosy's mail. I have issues with BOTH doors you mentioned.
1. Water fill door is locked shut for eternity, I think. The PO lost the key and I have no way of opening that door. I pulled part of my dinette out to look in that area, and all the wood looks great.....so far. How can I get another key, OR, how can I replace that lock with another cam lock? Mom will never go boondocking with me, but I'd still like to have that door operable.
2. You're 100% correct about my battery door. So much water had leaked in that it destroyed the wood below the battery box, and my battery ALSO was almost on the street! It looks like the rotten wood went right on top of the existing floor to elevate the battery just a bit. Am I right? I plan on replacing all that wood under the battery when my new converter and battery arrive. I'll certainly take your advice and any other suggestions you have. Thanks a million!
Old 11-29-2006, 02:40 PM   #25
Battery compartment repair
First, take digital photos of everything as you take it apart. It will be good for stories afterward -- and also to help you reverse the process and put it back together.
I haven't heard if you have the twin bed or double. I have a twin. It's just a number of screws to remove the thin plywood under the roadside twin mattress. I opted to remove the entire bed frame and tambours -- it comes out easily as one unit with all perimeter screws removed. Haven't done it yet but I need to repair rear floor in the future -- taking the wardrobe and bathroom apart looks pretty tough.
See the Argosy Water Leak thread for an explanation about how I did this. Unhook your battery power cables at the Univolt end under your wardrobe. I had to remove the battery compartment door and black plastic battery enclosure. On your trailer you will observe that the battery sat at the back corner of one piece of floor ply; a different ply sheet for the bathroom area begins directly under the bed-wardrobe wall. My plywood overlay spanned onto both sheets so I could screw it down well.
There was originally about a foot square of 1/2" plywood under the battery compartment between it and the floor. Rivets in the black plastic enclosure only line up to those in the compartment door if you add this height back. So I simply used a larger rectangle of 1/2" ply extending over the top of sound floor all around the cut out rot. It made it fairly easy but was still a time consuming repair. You'll find that Airstream used a lot of double-sided foam tape to seal back then. A line of Sikaflex should work very well instead. I caulked everything up with Sikaflex 221 as it went back together and used Olympic rivets to reinstall the door. It's a very sound repair!
That's the simple version -- the leakage in mine went on long enough that the outrigger underneath was totally rusted away. Of course I wouldn't want the base of the corner rib suspended in mid air like it was! So it took some welding shop work before I could even do this repair.
For your water door -- RV keys were made in a very limited number of patterns. Pull your Argosy around to a few SOB RV dealers -- the crustier looking the better. You'll know it's your lucky day if they pull out a Mason jar of old keys.
Please ask if you have any questions -- and all you owe is to hang out here and practice a lot of teamwork! BTW, if you have a dinette I'd appreciate your posting a digital pic of the water tank layout. Thanks!
Old 11-29-2006, 02:59 PM   #26
Okay sierrajb -- it is very rare that a mod ever hijacks a thread ( yeah, right!) from the original question. So I owe you one!
Attached is a pic of the grey water tank when I had my back belly pan off. It is taken looking aft at the roadside front corner of the grey tank. You can see the city water intake at the bottom right edge of the photo. I know the grey water pipe was not above the floor on that side. This photo shows the grey pipe just inside the roadside fore-and-aft main beam (the one just inboard of the brake drums). There is no water use and no spigots or sinks on the streetside up front, so it never made sense that this line would be at the midline where your wet spot was. This photo establishes that they "stayed home" with the drain pipe on the street side. (Incidental: The powdery white appearance is from Metal Ready pretreatment of the Por-15 system. The outer shell of the grey tank is a galvanized steel box with what appears to be an inch or so of styrofoam insulation before getting to the plastic tank on the interior. And yes, in other pics it does have a heat duct from the furnace routed to this interior.)
Name:	Grey tank, roadside edge looking aft.jpg
Old 11-29-2006, 03:52 PM   #27
sierrajb's Avatar
Arlington , Texas
Canoe Stream,
FYI, my 75 Argosy has a twin setup also. Your description of the battery, etc. location is exactly as mine. I've printed both of your posts for future use.
I understand what highjacking a thread means, now. ha! My fault, I guess. We'll keep this thread focusing on the wet spot. I'll post a pic of my dinette and continue our discussion of the battery compartment repair on another thread.
Thanks for the priceless info. I'll try to contribute all I can to the forum.
Old 01-18-2007, 10:26 PM   #28
galfoman's Avatar
2002 19' Bambi
Dorchester , Massachusetts
Hey,
I'm having the same problem in my 2002 Bambi. It's been raining here for a few hours in Boston and tonight I removed all of the carpet to later install vinyl tiles.
I found a large wet spot on the floor at the left side of the refrigerator. The carpet was not wet and I have not had the fridge running in over 2 weeks so I think it has to be a leak in the A/C gasket and is leaking between the roof and wall panels.
It is very wet at the rear of the fridge and exterior wall and it flows inside of the cabin towards the front left corner of the fridge. The cheap plastic coated particle board cabinet that encases the fridge is soft with water damage from the floor up 4 inches. I will probably dry the spot with a space heater tomorrow and then spray the roof with water to make sure its the A/C but I have already scheduled to have it serviced.
I'll let you know what they say.
galfoman is offline   Reply With Quote
Argosy Motorhome Manual & Brochures WANTED Rik Argosy Motorhomes 28 05-22-2017 11:45 AM
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 8 05-11-2017 04:42 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Wet floor, finding & stopping leak Joseph O. Smith Repairing/Replacing Floor &/or Frame 4 03-24-2003 10:17 PM
1985 Argosy MH???? ViewRVs Airstream Motorhome Forums 8 03-21-2002 07:39 PM
