Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 09-11-2012, 08:56 PM   #1
pxlchk1's Avatar
1972 Argosy 20
Brookfield , Illinois
My rebellious step
When I'm stopped and actually want my step to come down, I can't get it to release for the life of me. Naturally, when I'm driving, the thing comes down at every stop.
Why does my step hate me? What can I do to get to cooperate? Am I the only one with a possessed step?
Alana
AirForms thread: Alana's '72 Argosy Project
Where I blog : Nest Vintage Modern
pxlchk1 is offline   Reply With Quote
Old 09-11-2012, 09:29 PM   #2
pxlchk1's Avatar
1972 Argosy 20
I guess the actual question is how *should* it be released an how should it be stowed? Because I'm either missing one thing or it doesn't function properly.
Thank you!
Old 09-12-2012, 10:29 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You lift up on the release handle. If the mechanism is working properly the step should drop down and lock into place.
There are notches in the track that hold the step in place once extended. These notches wear over time and need to be reshaped to hold the extended step properly.
You should inspect the latch mechanism that holds the step in the travel mode. Look for a broken spring or rusty components that prevent the mechanism from securely locking the steps in the travel position. It may only require a good cleaning and lubrication.
Old 09-12-2012, 09:40 PM   #4
pxlchk1's Avatar
1972 Argosy 20
I'll check it in the morning. Thank you!
