Old 06-10-2013, 09:43 AM   #1
1977 Argosy 24
Milltown , Wisconsin
My home-made Panoramic rock guards
Here is my attempt to save some money and make my own rock guards for the front windows of my 77 Argosy 24'. I used 1/2" electrical conduit and the pebbly grained fiberglass panels they sell at the home stores.
Name:	guard corner clip.jpg
ID:	187844   Click image for larger version
Name:	guard hold down.jpg
Name:	guard on clips.jpg
ID:	187846   Click image for larger version
Name:	Argosy front guard.jpg
ventport is offline   Reply With Quote
Old 06-10-2013, 09:45 AM   #2
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
This is a great idea! Let us know how it holds up while traveling.
GAStreamin is offline   Reply With Quote
Old 06-10-2013, 01:18 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I built a similar unit out of the same fiberglass material. It has held up fine for 3 years and close to 15K miles of traveling.
Old 06-10-2013, 01:26 PM   #4
1981 31' Excella II
New Market , Alabama
How does it come on and off ?
Do you have some photos showing how the FRP board is attached to the pipe?
Perry
Old 06-10-2013, 02:54 PM   #5
GAStreamin's Avatar
Moultrie , Georgia
That is interesting! Conduit is cheap and not real heavy. I have used it to make drapery rods. Do you have a pattern for the shields? How does the fiberglass curve around? I am not familiar with that material. Can you make it other colors?
Old 06-10-2013, 02:55 PM   #6
GAStreamin's Avatar
Moultrie , Georgia
I guess the pebbly fiberglass material just bends around, but did you heat the conduit to bend it?
Old 06-10-2013, 03:08 PM   #7
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Show And Tell Us More...
Ventport, great idea and not that expensive either...Nice job, but show and tell us more.
GAStreamin, the metal conduit could be bent in a standard tube bender. Your local electrian should have on hand and the best thing is...No heating required!
Chris
newsgauger is offline   Reply With Quote
Old 06-10-2013, 03:42 PM   #8
maggieevans's Avatar
1966 24' Tradewind
Burnaby , British Columbia
Looks Great!
maggieevans is offline   Reply With Quote
Old 06-10-2013, 03:47 PM   #9
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
It does look really good! Great idea!
desertair27 is offline   Reply With Quote
Old 06-10-2013, 04:19 PM   #10
1977 Argosy 24
I used a conduit bender that I bought at Menards a few years ago to bend the conduit. Home Depot has them and they are under $20. I just held it up to the window and bent it by eye. I spaced it out with 1 1/2" foam insulation to see how it fit. The fiberglass is just pop riveted on with 1/8" pop rivets. The fiberglass panel is just wraped around the conduit frame. They are held on to the trailer with one bolt for each wrap window and 2 bolts for the center window. I got knobs for the bolts at my local hardware store. The nuts that they screw into were welded to the conduit frames. I used aluminum angle with a slot cut in it and riveted to the trailer that the panels hook into. The wing windows have 3 hooks, two top and one lower back and one knob and bolt lower front to attach to the trailer. The center guard has two pins that go into a hole in the wing guards at the top and two bolts with knobs on the bottom. Hope this and the pictures make sense. Brian
Name:	guard layout.jpg
ID:	187872   Click image for larger version
Name:	back side 3 guards.jpg
Name:	center guard top attachment.jpg
ID:	187874   Click image for larger version
Name:	knob wing window.jpg
Old 06-10-2013, 05:15 PM   #11
Kevin245's Avatar
Impressive. Best Airstream related idea I've seen in a very long time.
Kevin
Eleanor Roosevelt
Old 06-10-2013, 05:45 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sausage making ain't pretty, but I like your results!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-10-2013, 07:19 PM   #13
Savage68's Avatar
1974 Argosy 22
Hamilton , Montana
One aspect of this system that is most attractive is the limited number of mounting points required which also minimizes
the number of holes to be drilled in or near, the frame.
Savage68 is offline   Reply With Quote
Old 06-11-2013, 01:47 PM   #14
1977 Argosy 24
I checked and there are only 18 rivet holes. 10 of which are in the center of the rub rail so they would be covered by the plastic center piece if the brackets were removed.
Rock Tamers Mud Flap System au_ee Tow Vehicles 42 10-28-2016 06:50 AM
TAC Illinois Rally - Starved Rock SP - May 13 to May 15 Air Apparent Other Rallies & Events 4 05-14-2011 08:58 AM
Classic Airstream Motor Home T-shirt and gift items maltnhops Classic Motorhomes 0 03-18-2011 11:10 PM
Finally got it home - 1966 wworx 1965 - 1969 Globetrotter 9 02-02-2011 07:18 PM
Rock Guards on 2005 CCDs jordandvm 2002 - 2005 International 7 11-18-2004 10:02 AM
