Old 01-29-2012, 09:20 AM   #29
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Apologies for the brief diversion...
Originally Posted by TG Twinkie View Post
Take a look at my blog. I covered the refer vent without losing a lot of counter top space.
Excellent idea. Thanks!
Tom
mutcth is offline   Reply With Quote
Old 01-30-2012, 08:52 PM   #30
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
In days of old (the 1960's and 1970's) this was the known as The Airstream Curse among owners of Boles Aero, Avion, Silver Streak and Streamline trailers:
The case of the killer NT22C is 14" wide. The opening of the cabinet door is 13 1/2" wide. I cursed enough that the designer's grandkids' ears were probably burning. The center post between the cabinet doors is riveted in, and those are DOUBLE-blind rivets... pop rivets in where I need a mirror to see them, and the upper 4 have a 4" deep tray blocking drill access from the back.
At this point, it looks to me like this will require removing the entire lower galley . . . .
And why, right through the 1990's my parents were having to re-assure RV techs that their 28' Silver Streak was not an Airstream. Some wouldn't even show up due to this mistaken identity problem.
Bummer, brother. I do truly hope some piece falls into (or out of) place to make this easier.
Old 02-23-2012, 10:47 AM   #31
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Any progress?
Old 02-24-2012, 11:38 AM   #32
1981 31' Excella II
New Market , Alabama
Cutting torch or better yet a plasma cutter. Put some wet towles around the unit and have a fire extinquisher near by. A plasma cutter produces a clean cut with not much overspray. I bet you a local body shop would do it for you.
Perry
Old 02-24-2012, 05:37 PM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Perry
and video. from outside. with the fire extinguishers.
(actually, I'd do this)
Old 02-24-2012, 10:28 PM   #34
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Hmmm... I like the idea of cutting it up somehow, but I do think I'd feel like I was punished for taking the easy way out if the floor or cabinetry got burned. Remember, my cabinetry has that plastic woodgrain on it... it wouldn't take much heat to ruin the way that looks, I'm sure. It was 80 degrees here yesterday, it sure is easy to pretend it's never going to get cold again!
David
Old 05-11-2012, 06:06 AM   #35
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Aggie has started a thread on removing the furnace from his.
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 08:15 PM
Furnace Problem Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-05-2011 06:30 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
