Old 08-01-2013, 05:34 PM   #1
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
Mpg
Hi all,
Finally got away Tues morn on my way to PEI. I always keep track of mileage and this trip has confirmed data from the past. Whan traveling highways or interstates buying the mid grade pays off, usually. Most vehicles today require performance with reg. My TV an 07 4runner V6 and the towed is a '79 minuet weighing in at 4020# with a hitch wt of 460.
On reg gas the mpg is 13.2 hywy and 12 +/- mixed. Using mid grade the hywy mileage is 14.4 mpg. By my calcs mid grade is a bargain up to about .25 more per gal.
Has anyone else worked this out or am I just a bit anal?
Paul
tarnished is offline   Reply With Quote
Old 08-02-2013, 08:13 AM   #2
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
No, your not anal. My rig rig weighs much the same and gets 16 avg when using mid range or super on level. The Ridgeline's owner manual suggests using a higher grade when towing. The Ridge has a final gear ratio of 4.36.
Ahab is offline   Reply With Quote
Old 08-02-2013, 06:55 PM   #3
Bex
1976 Argosy 28
Eckville, Lacombe County , Alberta
Send a message via Skype™ to Bex
Thanks for sharing. My TV is diesel but its great that this info is available, I also have a 1/2 camper van that I have towed the trailer with and did wonder about the use of more costly fuel.
bex
Bex is offline   Reply With Quote
Old 08-02-2013, 07:29 PM   #4
1999 19' Bambi
Fort Worth , Texas
Did you pay particular attention to the ethanol content of your fuel? It would only take one or two tanks of E-Zero gas to let your average MPGs to shoot up.
mansaj is offline   Reply With Quote
Old 08-02-2013, 08:02 PM   #5
Tonganoxie , Kansas
What is E-Zero gas???
TWA640316 is offline   Reply With Quote
Old 08-02-2013, 08:42 PM   #6
1999 19' Bambi
Fort Worth , Texas
E-Zero would be regular mogas with no added ethanol.
E-85 = 85% ethanol
E-10 = Most commonly found now at pumps
Old 08-02-2013, 09:05 PM   #7
richinny's Avatar
2011 34' Classic
paul,
i've compared regular and premium. in my case with a .35 to .40 cent difference it worked out even. i still use the premium. the difference in price between the grades varies a lot from station to station. i might try the mid grade at some point.
Ricky
Old 08-03-2013, 12:05 AM   #8
2005 19' Safari
GLENDALE , AZ
If you currently cruise at 65-75 mph, you'll save more gas by slowing to 55-60 instead of switching to higher octane fuel. In fact, the mileage on our 2008 Tundra CrewMax, towing our 19-foot Bambi, goes from 13.5 mpg at 60 mph, to 16.5 mpg at 45, when driving in the Rockies.
Old 08-03-2013, 07:53 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I find I get a little more zip at altitude using higher octane and travel at 60-65. But you are right about 45, traveling in a caravan last year at that speed I got 20.3. but that was tedious.
Old 08-04-2013, 03:45 AM   #10
Topping , Virginia
I've been using 10%. Cruising speed is usually between 55 & 60.
Paul
Old 08-05-2013, 11:34 AM   #11
Topping , Virginia
Have used e-zero beginning yesterday and through arrival at Bayside on PEI
Have averaged 15.8mpg in mixed but 65% hywy driving. Kinda helps to
ease the 5.20 / adjusted gallon.
Paul
Airstream parkway 2006 2500 mpg with toad? Jgjimgrn Sprinter and B-van Forum 3 03-03-2012 12:03 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
2011 Tundra Double Cab TV mpg Goal15 Tow Vehicles 3 08-06-2011 11:11 AM
Truck Shells and MPG Secguru Tow Vehicles 25 02-20-2011 04:57 AM
