Old 06-29-2012, 09:55 PM   #1
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Minuet Floor
What year and/or model Minuet had an aluminum floor? And would that help prevent frame rot?
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 06-30-2012, 02:01 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
Anna , Illinois
Images: 183
Minuet Floor
Greetings tiger!
As with Airstream, there are few absolutes with Argosy travel trailers from the first generation. The 6.0 Metre Minuet (1977-1979) is the most common coach with the composite aluminum floors, but not all of these coaches came with these floors. The 6.7 Metre Minuet (1977-1979) constitutes a small number of the coaches with the composit aluminum floor . . . it seems, however, that more 6.7 Metre coaches have plywood subfloor rather than the composite aluminum. The 7.4 Metre Minuet (1977-1979) does not appear to have been produced with aluminum composite floors as I am unaware of any reported 7.4 Metre coaches having aluminum composite floors.
I am afraid that I can't anwer your question about problems with interaction between the steel frame and the composite aluminum floors. The biggest problem that I have heard reported with the composite aluminum floors is a tendency for "ruts" to form in high traffic areas that can complicate the installation of laminate floor coverings.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 06-30-2012, 07:03 PM   #3
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
The aluminum floor MIGHT help prevent frame rot, but I wouldn't count on it. The rust I've seen on frames came from water getting onto and staying on the frame. That was from leaks from the back running down inside the frame. Folks that have redone the floor in their Argosy might chime in here as they would have seen evidence that the wood floor was hard on the frame.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 06-30-2012, 08:14 PM   #4
1974 Argosy 28
Images: 37
Arrow
Kevin and Argonaut, thanks for the input.
I noticed you both have a 78 6.0 Do either of them have aluminum or wood?
Old 06-30-2012, 09:38 PM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Minuet Floor
Greetings tiger!
My Minuet 6.0 Metre has the composite aluminum floors. I am the second owner of the coach and it has had regular seam sealing so leaks have been kept under control. The bellypan has only been off of a small portion of the coach below the rear bathroom and there was no evidence of rust . . . there was a little surface rust where the paint had been scratched on the frame. I don't know whether the factory placed an paticular type of material between the frame rails and the composite aluminum floors, but with my limited visual inspection there didn't appear to be an excess of corrosion on either surface. The problem with "ruts" is minor in my coach, and the interior floor covers is Armstrong laminate flooring with Armstrong Quiet Step Underlayment.
Kevin
Kevin D. Allen
AIR #827
Old 07-02-2012, 07:50 AM   #6
Argonaut20's Avatar
1966 17' Caravel
I have had the rear belly pan off my '78 and I didn't find much indication of corrosion or rust on the frame. I owned a '79 with a wooden floor and there was surface rust on the frame attributable to water running down from the hose/electrical pigtail storage compartment and being held on the frame by the belly pan. POR15 or Rust Encapsulator is a good paint to put on the frame whenever you drop the belly pan.
As for the floor, I, too, have put laminate floor down and have no trouble with hills and valleys in the floor. I would say that laminate flooring is a 'must have' for those aluminum floors.
2006 Toyota Tacoma
Old 07-02-2012, 08:51 AM   #7
1974 Argosy 28
Images: 37
Arrow
Thank you both for the info. Now I need to find one at a reasonable price. Love my 28' but would like to have a 6.0 also.
Old 07-02-2012, 10:00 AM   #8
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
There's one listed in the forum classifieds right now.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-02-2012, 12:42 PM   #9
1974 Argosy 28
Images: 37
Are you talking about the 1977 for 10k. Ah yah....a little out of my price range
Old 07-02-2012, 03:11 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
That's the one I was talking about. Hope you find something in your price range.
Becky
1964 Bambi II
1988 Avion 32S
Old 07-02-2012, 09:58 PM   #11
1974 Argosy 28
Images: 37
Thanks Becky for keeping an eye out. I did a shell off floor replacement and complete renovation on my 28' and enjoyed every minute of it. I hope to find a minuet that's needs some work but this time keep it as original as possible. I just hope I have the patience to wait for the right deal.
Old 08-16-2012, 09:39 AM   #12
1974 Argosy 28
Images: 37
Did the 1972 20ft Argosy's come with aluminum floors?
Old 08-16-2012, 11:34 AM   #13
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Nope - but that 1972 is a foot wider, which helps it feel more spacious than the Minuet. (You do also give up a second streetside window and the grey water tank.)
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 08-16-2012, 02:38 PM   #14
1974 Argosy 28
Images: 37
Tom
Do they use the black tank for the gray water?
