Old 09-21-2015, 12:15 PM   #1
1976 Argosy 28
Ann Arbor , Michigan
Macropoxy Paint
I am looking to repaint our 1976 28' Argosy and wanted to see if anyone has used Macropoxy Paint from Sherwin Williams. It says it is suitable for Marine applications and it is reasonably priced per gallon.
Macropoxy 646 - 100 - Protective & Marine
abauer335 is offline   Reply With Quote
Old 09-21-2015, 06:26 PM   #2
1975 Argosy 26
Cantley , Quebec
Macropoxy
I don't know if this paint can be applied on aluminium. It is not specify for aluminium, only steel.
For my argosy 26ft 1975, I will prime all the trailer with interlux interprotect 2000e and paint the with interlux boat paint. The rool and tip method.
I did that on my boat and was veru nice. This paint is a self leveling paint.
Manrique is offline   Reply With Quote
Old 09-21-2015, 07:04 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Macropoxy Paint
Two gallons of Imron 3500 HG will cover any Argosy trailer. (If applied properly)
The Sherwin Williams stuff might be good, but I know the Imron is excellent.
If you buy it right, two gallons plus activator will set you back about $250.
If you sand the aluminum well, it WILL stick, no primer needed. I guarantee it. (As I suspect the Sherwin Williams stuff will also)
I have some trailers I painted with the Imron over five years ago, no fading, no chalking, no peeling. It is still impressively shiny and very durable.
You are way ahead of the crowd by selecting a true epoxy)
Brevi tempore!
Old 09-21-2015, 07:15 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Name:	ImageUploadedByAirstream Forums1442884430.149456.jpg
This paint is over five years old now.
It isn't a great picture to show the wear, but there is nothing hiding in the shadows...
It still looks great.
Brevi tempore!
Old 09-22-2015, 05:22 AM   #5
1976 Argosy 28
This is an Argosy so it is already painted. Just needs I imagine a light sanding. The people at Sherwin also recommended a product called Sher-Kem. It is a metal finishing enamel. The big difference is no hardener and thus about half price. They say it is easier to work with but I imagine it may be less durable but the difference may be negligible. No idea. Any opinions about that?
Old 09-22-2015, 06:35 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The only reason I would not use an activated paint on a vehicle I cared enough about to do a respectable paint job on is if it was absolutely not in the budget.
Brevi tempore!
Old 09-22-2015, 07:03 AM   #7
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
Will any of this stuff smooth the seams in the interior ? I need to renovate a 79' argosy
paddle whisp is offline   Reply With Quote
Old 09-22-2015, 07:53 AM   #8
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
No paint will smooth seams, not really anyway.
What do you mean by smoothing seams though?
A hard edge can be softened some by sanding, but uneven edges have to be dealt with more aggressively.
Brevi tempore!
Old 09-26-2015, 05:25 PM   #9
1976 Argosy 28
Argosy update
Half way done thanks.
Old 09-27-2015, 05:31 AM   #10
1975 Argosy 26
Cantley , Quebec
Do you have pictures to see the progress?
Old 09-27-2015, 05:34 AM   #11
1975 Argosy 26
Cantley , Quebec
This is my argosy at the beginning of the summer. Now, the belly pan is finished and everything sealed up and ready to be painted
Old 09-28-2015, 08:35 AM   #12
1976 Argosy 28
Before, Midway, After
I cannot seem to upload the photo to the thread but follow the link and there are before, midway, and completion photos. Still have work to do on the stripe, put in maple floor, and other minor updates but there you have it.
http://www.airforums.com/photos/showimage.php?i=38114&catid=member&orderby=title&d irection=ASC&imageuser=102331&cutoffdate=-1[/IMG]
Old 10-01-2015, 11:53 AM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It matters not, I haven't been able to view 90% of the photos on AirForums in some time...
Might be punishment...
Brevi tempore!
Old 10-01-2015, 01:35 PM   #14
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Ah...I followed your link and it looks great, So did you go with the macroproxy paint and what steps did you need to do....sand, strip or prime etc..
How strong is it, are you familiar with how to do a paint bond test? At my sign shop we paint out a small area let it cure and then scratch the test area with our fingernails to see if it scrapes off and then the second test is a tape test, use clear packing tape or scotch tape and burnish it on well and rip it off and if the paint comes up we use a different product.
I'm just curious as the Manrique said the label looks like it wasn't good for aluminum but it looks pretty darn good and i have an Argosy to paint soon. What colours did you use?
thesignlady is offline   Reply With Quote
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
paint or not paint PeterH-Airstreamer Airstream Motorhome Forums 15 01-22-2003 09:27 AM
