07-12-2014, 06:18 PM
1973 Argosy 24
Kitchener
, Ontario
LPG lines
Just got a look under my 73 Argosy 24 and was surprised to see the lpg gas lines exposed beneath the belly pan. Is this normal? Myself I would have put them inside to protect them from road hazards. Granted it is much easier to check for leaks etc. with the lines exposed. I suppose there are good arguments for doing it either way. What was the norm?
07-12-2014, 06:25 PM
1972 27' Overlander
Denver
, North Carolina
It is exactly the way it should be. Picture in you mind if you will, propane gas laying inside the belly pan of your Argosy...that's why they are outside.
Lucky Dave, Denver NC
07-12-2014, 06:33 PM
1980 20' Caravelle
Ogden
, Utah
For safety, it is I critical that all connections are exposed and that the bulk of the tubing is outside of the trailer. Should there be a leak, you want it to dissipate and not build up anywhere.
07-12-2014, 06:34 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Outside the belly pan. LP is heavier than air. Ever seen the end results of a boat blowing up due to vapors in the bilge? Not pretty!
Aaron
WBCCI #XXXX AIR #2495
07-13-2014, 07:05 AM
1973 Argosy 24
Kitchener
, Ontario
Thanks to all for your responses. Sorry i'm such a noob, asking dumb questions.
07-13-2014, 07:23 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Only dumb question is the one that doesn't get asked and causes you pain and suffering.
Aaron
07-25-2014, 06:59 PM
Vienna
, VIRGINIA
No such thing as a dumb question. I was just under mine pondering a belly pan removal and "clean out". This story was fresh in my mind so glad to see them there.
Leaking propane tank likely cause of Feltonville food truck explosion | 6abc.com
2001 Ford Excursion 7.3L
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
LPG Lines.
boatdoc |
LP Gas, Piping, Tanks & Regulators |
2 |
01-23-2007 08:34 PM |
Horizontal LPG Bottles on "Limited" models
Dwight |
15 |
05-31-2005 07:18 PM |
Fix or replace LPG regulator?
Roundhead |
26 |
03-27-2004 03:28 AM |
What you wanted to know about LPG and more
femuse |
0 |
04-24-2003 10:12 AM |
LPG or propane in the bottles ?
brunoffrance |
3 |
12-17-2002 03:18 PM |
