Old 10-04-2006, 03:03 PM   #1
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
LP Gas Lines
The LP gas lines under the 77 Argosy all have shut-off valves where they enter the body to each appliance. Was this "factory" design or were the safety valves something a PO installed? I used a pair of pliers and couldn't get the valves to budge to open. So, I have yet to check for propane leaks or operation of any appliances.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-04-2006, 06:15 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The valves where the lines enter the belly pan is the standard. The theory here is that the valve is the most likely place for a leak to happen. Leaks would go onto the ground and not into the trailer. The stove line is not under the trailer, but inside the stove. Not sure why this one is different. Good luck with your valves.
Richard
Old 10-04-2006, 06:32 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I also think that the theory might have included the safety factor with being able to go outside to shut the appliances off of course every vintage unit I have ever seen the valves are solidly stuck in the on postionbut I guess that is why there are valves on the tank FWIW I will probably replace mine, just for convenience sake. It makes it easier if you need to isolate a piece of equipment without shutting down say the furnace in the dead of winter.
Aaron
WBCCI #XXXX AIR #2495
Old 10-04-2006, 07:22 PM   #4
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
With newer flex or rubber lines now on the market can they be used to go up thru the belly pan, then floor?
'77 Sovereign Intl 31' CB
Old 10-04-2006, 07:33 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
The line thru the floor should be solid copper. I would check and see what the current RVIA(?) code is. As far as I know the rubber lines are only supposed to be used at the tank to regulator connection. There are a couple different types of copper tubing IIRC they are K,L, and M. They have different wall thicknesses. At one time they used to specify a tin lined copper tubing but I haven't seen that stuff in years. Typically a gas system will be plumbed with one of the 3 with K being the stiffest and M being the softest. Then you can get into the differences between annealed and drawn BTW I use what I buy at my local home improvement center typically the stuff in the rolls...
I suspect the general idea is to minimize the number of connections inside the unit in an attempt to avoid deady gas leaks. In most SOB's there is a black iron pipe run down one of the frame rails with the various appliances feeding off of it.
Aaron
Old 10-09-2006, 08:38 PM   #6
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The Range & Oven Work !!!!!!!!!!!!!
By talking to the previous owner, I discovered that they never used the range & oven. She stated that the oven has a bad gas leak. That is why it was shut off and never used. Too bad she never knew about the pilot light shutoff. The oven control was only in the off position. The writing on the knob was well worn away. I put a new valve in and tested lines and everything works perfectly. Next--- to check the furnace!
WBCCI 17109
Old 01-24-2008, 09:25 PM   #7
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Smart PO
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
