Old 05-15-2014, 01:52 PM   #1
1975 Argosy 26
Azle , Texas
jacking points
Does anybody know where the jacking points are for a 26' twin? Thanks
mikeabe is offline   Reply With Quote
Old 05-15-2014, 09:35 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
For what reason do you want to jack up the coach?
Typically on a tandem axle trailer. The method of using ramps to raise one axle at a time.
It is by far the safest way to raise the coach.
Old 05-16-2014, 07:07 AM   #3
1975 Argosy 26
Azle , Texas
Thanks for the reply! I totally agree that using ramps are the best and safest way to work on one of two axles. In fact, this is the method we used to install new axles last month. What I'm concerned about is in the event we're traveling, having a flat tire and i don't have my ramps with me. I know the manual says that you can remove the faulty tire and are able to continue on your journey for a max of 100 miles at a speed of 30 mph or less, but removing or replacing the tire would probably require a jack. So I would really like to know where to jack it up. Plus, I'm just curious where the jacking points are. I wonder if they're are any jacking point stickers that haven't fallen off after 39 years
Old 05-16-2014, 07:13 AM   #4
Gainesville , Florida
Just drive one tire up on blocks and the other will be clear of the ground. Jim
Old 05-16-2014, 07:35 AM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
BUT, in answer to your question there should be 2 points indicated on the belly pan to the rear of the wheels that are jacking points. Look for a diamond shape rivited there. From these points ( one on each side ) you can lift both wheels. I use a piece of 3/4" plywood to help spread the lifting pressure. ( these also serve as bases for the stabilizers ). Do not, under any circumstances, try to lift by the axles. To change a tire along the road drive one wheel up on a couple of blocks of wood and raise the other wheel. I hope you carry a few blocks to aid with leveling ???? It will be much easier and safer than jacking.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-16-2014, 09:41 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
An AS dealer told me that you can jack any AS from any point on the longitudal frame members. Do not use the cross members.
It's always worked for me......for whatever it's worth.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-16-2014, 12:28 PM   #7
1975 Argosy 28
Parker , Colorado
Mike -
Just behind the rear wheel there is a section of the frame that the axles are bolted to - instead of the C-channel frame rail, there is a section of 4"/5" angle hanging down. If you look, you can see the end of it where it slopes back up to meet the main frame rail.
That is your jacking point - place the jack as close to the rear wheel as you can and proceed.
Be sure and loosen the lug nuts before you get the tire off the ground.
Bill
Willie G is offline   Reply With Quote
Old 05-16-2014, 01:44 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Instead of ramps, you might just consider carrying a couple of sets of Lynx levellers which can serve multiple purposes.
They can easily be configured as a ramp to change a tire, used to level your trailer side to side if needed on a bad site, or used as pads under the stabilizers, as many as needed, if your site is on a bad slope front to back.
They are light weight don't take up much space when stored, and ours remain in the trailer at all times just tucked in one side of the back storage bay.
Cheaper at Walmart than at Camping World I think.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-16-2014, 07:12 PM   #9
1975 Argosy 26
Azle , Texas
Thanks. I really appreciate the posts! It's just interesting to me how airstream picked that particular spot to be a jacking point. From what I've seen so far, there's no difference in the frame at that point. Maybe it has something to do with the center of gravity. Sorry for kicking a dead horse.
Jacking points jump Jacks, Stabilizers, Lifting and Leveling 6 03-28-2007 09:51 AM
jacking points emanon25 Jacks, Stabilizers, Lifting and Leveling 6 04-25-2006 03:10 PM
need to replace the wheel...are there jacking points? 60traveler Jacks, Stabilizers, Lifting and Leveling 1 06-25-2003 03:05 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
