Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 01-06-2006, 09:03 PM   #41
1960 28' Ambassador
Libertyville , Illinois
7.3 Metre Minuet Photos
Greetings mtnman!
I love your Minuet! This is the model that I too would love to own! I have been trying to collect 7.3 Metre photos in hopes of one day finding one that I can restore. Here are the some that I found on Ebay - according to the listing, the VIN is 24T9V6142 - perhaps someone could confirm for you that this is infact a 7.3 Metre Minuet as the Ebay add called it a 24 foot. BTW, you asked about value, someone paid $3550 for this one on 8/7/04.
Good Luck on your restoration!
Short563 is offline   Reply With Quote
Old 01-07-2006, 08:57 AM   #42
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Its a Minuet!!!
Greetings mtnman!
Originally Posted by mtnman
Yep, thats it, at the bottom of that brochure!
The tag I found on the side of the coach calls for 775-R15 tires and 35 PSI. Isnt that a little low on tire pressure?
mtnman
My '78 Minuet came with its brand new, never on the ground spare tire and wheel -- it is a load range C, Good Year Marathon belted-bias ply tire. The inflation recommendation, according to my understanding, reflected the tandem axle configuration on the 7.3 Metre as my single axle 6.0 Metre requires the same inflation pressures according to the manual. On my single axle, however, I tend to run at the maximum inflation pressure posted on the sidewall of my Good Year Marathon load range C radials as I am within a very few pounds of my GVWR for the coach when traveling.
When you purchase new tires for your coach, ask your tire dealer for an inflation chart for your tires -- the chart should indicate the weight carrying ability of the tires at various inflation pressures. With the pressure/weight capacity chart and the GVWR rating for your coach you can arrive at a plausible minimum inflation pressure
Good luck with your Minuet!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 01-07-2006, 04:56 PM   #43
mtnman's Avatar
Collettsville , North Carolina
Originally Posted by Short563
Greetings mtnman!
WOW! Its just like mine!
mtnman
mtnman is offline   Reply With Quote
Old 04-13-2006, 04:43 PM   #44
1978 27' Argosy 27
west monroe , Louisiana
i need one of those plastic wheel caps that say argosy anyone have an extra for sale
oldwingrider is offline   Reply With Quote
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
A little treat for the Minuet owners. barbwire All Argosy Trailers 14 11-14-2002 09:25 PM
Minuet 6.0 History? ARGOSY79 All Argosy Trailers 2 10-06-2002 02:12 AM
