Old 06-29-2015, 06:51 AM   #15
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
Originally Posted by Denda View Post
Looks great! We have a 1972 22ft Argosy also. It is getting a new paint job as we speak! We are hoping they call us next week and tell us to come get it!!
We have left the interior original, so it looks almost just like yours.
Please post some pictures of the new paint when you get it home.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 06-29-2015, 07:13 AM   #16
mandolindave's Avatar
WOW …it looks mint
I bought a 73 Argosy 20' in original working condition. The fridge worked great…but was leaking ammonia gas. I'd keep an eye on it.
I was advised that the original water heater was an accident waiting to happen.
Then the furnace died, on a freezing Fourth of July night. ( true story )
mandolindave is offline   Reply With Quote
Old 06-30-2015, 06:04 AM   #17
Denda's Avatar
1972 Argosy 22
Dumas , Texas
I will.
Denda is offline   Reply With Quote
Old 07-01-2015, 04:39 PM   #18
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Close call!
I went to turn on the roof vent fan and it did not work. I left the vent open a few nights ago and rain came in through the vent and must have got the motor wet. I flicked the switch a couple times and still nothing so I figured it had died because I left the vent open. I came back a while later to pull the motor out and it was smoking! I had left the switch to the on position. It was so hot the fan melted on the shaft. I turned it off and had to let it cool down for a while before I could take it out of the vent. I am sick to think I could have burned the camper up. A new motor and fan blade are on the way from Inland Marine so all will be fixed soon. SCARY!.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 07-06-2015, 01:34 PM   #19
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
You could have maybe salvaged the old fan at first. Mine would not turn either so I took off the screen and turned the blades by hand and off she went. A dose of WD40 and it works like a charm. Since it toasted you will need a new fan now. I suggest replacing the switch as well with a DPDT center off switch so that the fan can be reversed to blow air into the coach.
Gearheart is offline   Reply With Quote
Old 07-07-2015, 07:36 AM   #20
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I had figured on doing that put did not know the correct name for the switch I needed to make it work. Thanks for the info.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 07-08-2015, 08:29 AM   #21
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
They come with 6 contacts on the back, (: : like this. Connect power and ground to the middle contacts. Cross connect the outside contacts, i.e. right front to left rear, left front to right rear. Connect the power and ground wires from the fan to one end only, i.e. right front and right rear. The switch will connect straight in one direction and reverse in the other.
Old 07-17-2015, 03:07 PM   #22
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Exclamation Motor will not run backwards
Disregard my last 2 posts. The motor is not reversible. I bought the switch and installed it and much to my chagrin, reversing the polarity also reverses the polarity of the field coil magnets and the fan still goes the same direction.
Old 07-18-2015, 04:47 AM   #23
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Thanks for the update. I installed the new fan and its working great.
Old 08-06-2015, 05:51 AM   #24
Denda's Avatar
1972 Argosy 22
Dumas , Texas
Before
Old 08-06-2015, 05:53 AM   #25
Denda's Avatar
1972 Argosy 22
Dumas , Texas
After we stripped the paint.
Old 08-06-2015, 05:54 AM   #26
Denda's Avatar
1972 Argosy 22
Dumas , Texas
Finally have her home!
Old 08-06-2015, 05:57 AM   #27
Denda's Avatar
1972 Argosy 22
Dumas , Texas
One more
Old 08-06-2015, 06:32 AM   #28
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Man! Thats RED!
Nice work! I can see you from here.
WALLY BYAM MAN CAVE sign PauseReflect Airstream Classifieds 0 11-08-2013 06:16 PM
Man Cave :: 2012 Airstream Tradewind DJLivewire Airstream Registry Discussions 0 07-21-2012 09:30 PM
Thank god for my man cave noreen&sal Off Topic Forum 15 01-07-2011 12:10 PM
One man's trash is another man's treasure richie rich Generators & Solar Power 29 02-16-2010 06:07 AM
