Old 06-03-2013, 12:40 PM   #1
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Introducing il Progetto
So, considering the list of tasks I've already made in my head, and the length of time it'll likely be before the new addition is ready for easy, comfy travel, I have named this one "il Progetto" in part to set the right expectation in my mind and my partner's.
Curiously, both my '75 Argosy24 and this new one were listed with no photos and fairly minimal description on my local craigslist. Weird coincidence?
Sunday 2 June I agreed to purchase (and exchanged a cash deposit for a written sales agreement for) a 1976 Argosy 28' Center Bath trailer north of Paris, TX. It's right at 150 miles from our house, so compared to the Kentucky Expedition it was right next door, and absolutely a night-and-day difference in the situation. The seller was quick to tell me "it ain't no cream puff" and he was not wrong, though compared to the disaster in Kentucky it's pretty close to cream-puff status!
Money-wise, this it its worst angle. That curbside rear pano is plexiglass, and the panel below it will need some expensive help. The owner before the current seller had put some sort of heavy rack where the bumper belonged, and the current owner just lopped it off, assuming (correctly) that it was bad juju and he reconnected the subfloor to the shell where the abomination had started to separate it. It's not the most professional repair, and of course the bumper is still missing but I have a plan.
The subfloor is mostly good, though there's some thin OSB laid over parts of it as a platform for carpet that the current owners replaced with stick-down tiles. It's fairly haphazard, so I was able to access the edges of the real subfloor in most places and only found real rot in an unsurprising place, between the rear edge of a wheel well and the battery box. It's possible there are some unpleasant surprises lurking under the underlayment, but probably (hopefully!) not in structurally-sensitive places.
The seller is a master plumber and has redone the previous shade-tree-mechanic nightmare of copper and various hose clamps and garden hose with well-done red+blue PEX with crimped connections. Unfortunately, he chose to retain the enormous electric residential water heater that occupies nearly all the galley cabinet and causes an external eyesore, but that's going. Anyone need an electric water heater?
As you can see, the owner prior to the current sellers really, really loves screws. He thinks they're wonderful. He likes ugly plumbing fittings, too, and apparently used regular green garden hose as his supply line in addition to his plumbing patches, but the plumber uses white hose and removed all the old stuff except the water heater (that he flushed before rebuilding the plumbing) so there's probably not much lead left in the lines.
It has an AC unit the works really well but drools on the shell, no condensate provision. It gets its power from a bit of maybe-20A extension cord wired into the box, so there's my excuse to go for a Marinco or Furrion inlet.
It still has a Univolt, and the dead battery was HOT, true to form.
I'm keeping the 24 at least until the 28 has run through my bank account and is ready for the road, so I can take time to do it right! And take lots of pictures, of course. Here's one last one of the "chandelier" that will be staying with the sellers, but the plumber has forbidden his wife from putting it into their newer trailer.
David
Old 06-03-2013, 12:51 PM   #2
1981 31' Excella II
New Market , Alabama
Looks like you have a project. Good luck on the rebuild.
Perry
Old 06-03-2013, 04:14 PM   #3
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Congrats on the project. I'm waiting to hear about project Argosy #3, the window donor...
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 06-03-2013, 06:34 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
Tom
I'll post some horror shots if I get the one I'm going for. It's one I won't be sad to sacrifice for a good cause. I'll own it long enough to get the useful stuff off it, and never bother with that pesky title business if I can avoid it.
David
Old 06-03-2013, 08:03 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Congratulations! Looking forward to seeing il Progetto soon.
Lance
Top is offline   Reply With Quote
Old 06-03-2013, 10:19 PM   #6
1974 Argosy 20
Kooskia , Idaho
You MUST keep the hanging lamp! MUST, MUST. It is so classic and right for Progetto.
Old 06-03-2013, 10:27 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Agitator!
It's 120v for one thing. It's too late in the day to get into the aesthetic questions.
David
Old 06-03-2013, 10:31 PM   #8
1974 Argosy 20
Kooskia , Idaho
Originally Posted by DKB_SATX View Post
Agitator!
Use an inverter, or I will send you a 12 volt 50 watt screw in bulb.
Old 06-04-2013, 10:14 AM   #9
DKB_SATX's Avatar
1976 Argosy 28
Dealing with reality
Ah, numbers are such fun.
I started on a rough "task list" at the level of remove stupid residential water heater, install RV water heater, install 2-way fridge, new axles, etc.
31 line items so far, and the rough estimate on the parts has pushed through the $6k mark. OUCH. Ah, well, you can do it right or do it cheaply, I plan to travel a lot in il Progetto so doing it right the first time will (hopefully) make for less headaches on the road or in camp.
David
Old 06-04-2013, 02:02 PM   #10
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Or you could always throw a disco ball in there!
Good looking trailer you got there. Funny you're going up in trailer size and I'm going down.
Mike
desertair27 is offline   Reply With Quote
Old 06-04-2013, 02:14 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
re: Going up in trailer size: Well, it's the smallest vintage trailer with pano windows front and rear. Besides, the sum of your trailer lengths is pretty long, I'll only be around 52 feet of trailers, with the 3 in your profile plus the Safari you just bought you're around 95 feet! Do you not have the trailer you took to the Balloon Fiesta anymore, or is it just not listed?
David
Old 06-04-2013, 03:54 PM   #12
Sphere Guy's Avatar
Livingston , Texas
Congrats David! Now we know you truly have the "sickness" and belong to the MAOG.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 06-04-2013, 05:02 PM   #13
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I will not buy another Airstream, I will not buy another Airstream..............
HAHAHAHAHAHAHAHAHAH!!
Nice find, good luck on your restoration. I look forward to seeing it.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 06-04-2013, 05:25 PM   #14
Central , Mississippi
il Progetto will become il Progetto Estenuante prior to completino...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
restoration
