Old 07-07-2013, 08:57 PM   #43
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Ah, Murphy... you always win.
On Saturday we had both professional and family social obligations, so I didn't even try to work on the 28. I was going to head over this morning to get a few things done before it got hot... but to be polite about it, "gastrointestinal distress" sidetracked my day. I didn't get anything done (trailer or otherwise) but I'm not as whiny and delicate as I was earlier, at least.
On Friday I proved to myself that things were about as I guessed (and tried not to think about), I'll need at least one new section of subfloor. I guess I'll need to organize a bit in the garage so I can bring some of the interior parts over here to store them safely while other work is done. It ain't gonna be cheap, but it'll sure be solid when we're done. I'll at least be confident it's ready for another 30-40 years of travel.
My favorite tools of the week: Dewalt cordless drill and my ShopVac.
— David
Old 07-14-2013, 06:52 AM   #44
lcurrie's Avatar
2005 19' Safari
David,
Have you used one of these yet?
http://www.amazon.com/gp/aw/d/B00005...dir_mdp_mobile
By far, my favorite new tool.
Lynn
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 07-14-2013, 10:34 PM   #45
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by lcurrie View Post
David,
DEWALT DW920K-2 1/4-Inch 7.2-Volt Cordless Two-Position Screwdriver Kit:Amazon:Home Improvement
Lynn
I haven't... I generally just use the big DeWalt for screws, and a hand tool if it doesn't fit. I think a PEX crimp tool is the next tool for the kit... I'll have to plumb in the new water heater, and reconnect the pump to the system. The plumber who owned the trailer before didn't hook that up when he did the nice red-and-blue PEX re-plumb.
— David
Old 07-15-2013, 12:17 AM   #46
DKB_SATX's Avatar
1976 Argosy 28
I cut a big hole in my trailer today
I decided to remove the polarity light and replace it with a Marinco 30A inlet, since one previous owner or another had lopped off the shore power cable just at the belly pan and replaced the end with a 15A plug... as inconvenient as it is unsafe.
So, I had a look at the box that houses the lamp and wiring for the polarity light. It also has an expanded-foam infestation.
It's a junction box with one line running in from the breaker box and 2 running out to other parts of the trailer, I'm assuming to the 120v outlets. It has the weird cross-connection for the polarity light.
I fiddled and piddled and put it off... but eventually it was time to cut a Big Honkin' Hole in my new trailer.
I didn't want to. I managed to get it in the right place, at least, but cutting a 2 11/16 hole in the side of the trailer was intimidating. It's pretty final! I forgot to take the piece of romex to run from the Marinco to the box, and we had a thing this afternoon, so I just did a test-fit to plug the hole and make sure I didn't screw it up too much.
The Marinco is clearly the shiniest thing on the trailer!
— David
Old 07-15-2013, 04:22 AM   #47
247stream's Avatar
1986 25' Sovereign
Marietta , Georgia
cutting a hole in your trailer?! a brave step that and you did very well
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 07-15-2013, 05:21 AM   #48
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
There is always hesitation to cut a hole in the skin. Just a normal thing.
The reverse polarity light j-box there looks as if someone repurposed it as a normal junction box and the reverse polarity light combo? I believe there was some type of limiter/resistor originally. Doesn't really matter, since you are re-doing it all with the Marinco.
Enjoy the rain!
Lance
Top is offline   Reply With Quote
Old 07-15-2013, 08:23 AM   #49
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Hey David
Here's a couple of pictures of the window I have.
Mike
ID:	190952   Click image for larger version
desertair27 is offline   Reply With Quote
Old 07-15-2013, 10:36 AM   #50
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by desertair27 View Post
Hey David
Mike
That looks like just the ticket. Whenever it's convenient to ship, just tell me how much the shipping is and how you'd like the payment.
— David
Old 07-15-2013, 10:43 AM   #51
DKB_SATX's Avatar
1976 Argosy 28
Enjoy the rain!
The wires in the polarity box were about what I expected from the wiring diagram for a center-bath Airstream from my '75 service manual. I only expected one set coming in from the breaker box and one going out to the trailer, with the weird polarity-light cross connection so the 3rd stretch of romex was "extra" but I can deal with that. I'll have to figure out what to do to safely/securely house those wiring junctions, but it's under the bed so I may just use a small surface-mounted box to keep them accessible and avoid cutting up the inner skin any more.
There may be a resistor or something built into the tube that houses the lamp for the polarity light, I haven't looked in there yet, nor have a put a meter on it. There wasn't anything wired in.
— David
Old 07-15-2013, 11:54 AM   #52
whitsend's Avatar
1954 25' Cruiser
Kyle , The Republic of Texas
Originally Posted by bwoodtx View Post
I will not buy another Airstream, I will not buy another Airstream..............
Oh Bruce. You are SO in such deep denial. And I can't help you. I can only enable you. To facilitate so to say. But if you are to advocate the above silly statement, you really need to find a good shrink. Preferably a shrink that has an Airstream. Perferably a shrink with a vintage Airstream.
Folks - Lets just ask our Bruce what his plans are for the upcoming weekend.
Bruce . . . Bruce . . . Bruce . . . Talk about someone that has gone, like, WAY overboard? Including the one coming home to San Antonio this coming weekend . . . what is the current count of Airstreams rescued, and now somewhat safely stored on your Texas estate? Conspicuous consumption? Be honest with yourself now . . .
I love that old time rock & roll.
whitsend is offline   Reply With Quote
Old 07-15-2013, 12:39 PM   #53
DKB_SATX's Avatar
1976 Argosy 28
Is there a story here, Jim? have you heard something or are you just playing the odds, figuring that if it's been a few weeks since Bruce bought one, he's bound to have found another by now?
— David
Old 11-06-2013, 11:42 AM   #54
DKB_SATX's Avatar
1976 Argosy 28
My but it's been a long time! The sweltering heat of August and September really reduce my appetite for working in enclosed spaces with no AC, and a few other events intervened as well. I'm a month or so out from my place in line at Top's shop, so I figured it was time to get back to this.
As mentioned earlier, the aft section of subfloor is slated for recycling. Instead of fixing it property, the PO cobbled together a strap that ties the shell to the frame in the absence of the last couple of inches of subfloor (and then replaced the OSB crap the owner-before-last put down) so the ends of the frame rails haven't dented the shell like that fence post did. I needed to get some more interior bits out to clear that area for work.
I've been thinking about ways to store the interior parts in my garage, but in the end I decided that it was too likely for things to get banged up and lost that way and channeled my inner American... I rented a storage room. It's close to where the trailer lives which simplifies several things, and now it contains all the loose interior parts that used to be in the bedroom. The gaucho goes to storage next!
The structure of the beds is still pretty good. The aftmost tambour is missing from the street-side bed, and I'll need to reattach the floor anchors to the curbside one because apparently some moron just pried them up from the floor before putting down that cursed OSB.
Here in a poorly-focused photo you can see the reason for all this effort. At least the beds were easier to remove than a bathroom!
The next section of subfloor forward is in pretty good shape, including the parts under the bathroom. I had already identified a patch that'll be required in that area, under the ravaged battery box. As you could see in the photo of the battery box in a previous post, some Einstein had cut a jagged 4-inch hole in the box to run cables through, so it's been a long time since it actually channeled any gasses out of the trailer during charging, and between external leaks and battery goo, the subfloor under the box and under the Univolt are done.
The areas around the wheel wells actually feel quite solid. Having the belly pan off for replacement may expose some issues there that I haven't found, we'll see. I'm pretty sure I'll want to replace the front section of subfloor, but I haven't removed the gaucho and freshwater tank to inspect there yet. I did find that one PO or another just covered up rodent droppings on a swatch of original carpet in the bottom of a cabinet with more of that bloody OSB.
I'm quite confident that it was original carpet, because underneath it was a collection of aluminum shavings and pop-rivet shafts.
I started work to remove the stupid electric water heater. That was a real treat! The 15A/120V water heater was plugged in with a homemade cord that ran back to a junky plug that was plugged into the same socket as the Univolt, with a light switch cut into the sink cabinet to turn it on and off. The strain relief on the junky plug wasn't even tightened down on the yellow romex. Oy. For some reason the water heater isn't draining, and of course no drain valves were installed during the conversion to PEX so I'm going to have to work on that next.
— David
Old 11-11-2013, 08:38 AM   #55
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
One has to wonder at some "fixes" made. I understand the frustation, yet, done once and done right would seem to make up for it . . even if not "perfect".
Old 11-11-2013, 10:47 AM   #56
DKB_SATX's Avatar
1976 Argosy 28
There are definitely some "fixes" on this trailer to be undone and done right. I hope to keep this trailer for a very long time, so even some of the things I "redo right" may need to be redone again someday during my tenure as owner, but should provide many years of use until then!
— David
restoration
