Old 06-18-2013, 07:21 AM   #29
lcurrie's Avatar
2005 19' Safari
Thank God for Duct Tape. And Sonic. And Caladryl.
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 06-18-2013, 09:59 AM   #30
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Congrats on your rescue, trailer rescues are much more fun when everything pretty much goes according to plan. Hate those chiggers!
Good luck on your pano window swap, I know Tops the man!
Mike
desertair27 is offline   Reply With Quote
Old 06-18-2013, 04:13 PM   #31
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Sorry that the chandelier didn't convey....think of the terrific stories you could tell!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-19-2013, 03:35 PM   #32
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Recovery Mission, Part 2: bringing il Progetto home
So, I didn't feel like it was enough to just rescue the parts trailer in a whole weekend, so on Sunday morning (16 June) I headed for Powderly, TX (another one of those towns I'd never heard of before I started this project... just north of Paris) to fetch il Progetto back to Fort Worth.
I don't think I was drinking when I inspected the trailer initially, but I remembered the tires being a bit nicer than they actually are. They're not cracked or dangerous-looking, but they looked a bit pale and weathered on Sunday. Maybe it's because it was 93 degrees and nearly that humid? I did notice initially that they're some brand I'd never heard of... "Rhoden" load range Ds. Ah, well, they'll probably keep the belly pan off the ground while I work on things. Only one of them was almost flat.
I peeled off the 1980s F150 plastic hubcaps so it would be easy to monitor the hub temps on the way home. Maybe I'll put them back on to make it look a little less scruffy at the RV storage place. It won't cost me anything, except thinking about old pickups every time I look at it.
The brake controller saw a braking circuit. Most of the lights worked, but the right turn/brake light wasn't working. I ended up getting it to work right with the bulb turned a few degrees so that it was pushed more firmly against the contacts. It did well enough to get me home, but I had to add another line to the task list.
Happily no one noticed the Oklahoma plate that expired in 2009. After a while the brakes actually slowed the trailer, but I'm sure they could use some adjustment. Odds are I'll only need them once more, I'll get new brakes and bearings with the axles it needs, after all.
It'll be sitting here for a while where I'll be doing a bunch of little jobs before Lance is ready to fix the wounded panel and pexiglass pano.
BAB: Alas, I still have that LOVELY "chandelier" in the trailer. I think the seller was afraid if he took it out, his wife would put it in their newer/bigger trailer. I asked him at least twice if he wanted it, while I was going through storage areas to find the last of their socks and t-shirts that hadn't made their way out of my trailer.
I'm considering some sort of ritual destruction of the plastic thing to purge the trailer of the spirit of halfway, slapdash, and half-hearted "fixes."
— David
Old 06-19-2013, 07:39 PM   #33
DKB_SATX's Avatar
1976 Argosy 28
New toys arrived today!
Parts for my projects are starting to flow in... today I received LED markers, an LED upgrade scare light and a warm-white version of the very bright 1156-base LED lamp for the porch light.
I ordered a big lot of LED lamps to replace the 1156 incandescents in all the interior lighting, but those will take a while. It's not like I'll be camping in this one anytime soon, but I hate waiting for toys!
— David
Old 06-27-2013, 09:02 AM   #34
TinyFixation's Avatar
1977 Argosy 28
Chester , New Hampshire
I'm so looking forward to seeing what you do with all of your trailers! When it comes time to sell donor parts you didn't need, I might be in the market to buy a couple of items from you. Your donor looks like it has at least two out of three on my list!
Maybe put a small dent in that $6K initial estimate for new parts you mentioned .
Don't judge an Airstream by the color of its skin!
Meagan
1977 Argosy 28
WBCCI#1528
AIR#73368
TinyFixation is offline   Reply With Quote
Old 07-03-2013, 04:56 PM   #35
DKB_SATX's Avatar
1976 Argosy 28
Work begins in earnest!
I'm going to use my holiday weekend for getting started on my projects for il Progetto. So far, if I count what I spent on the parts trailer, I've now spent more than half again my original purchase price of the 28' center-bath on the renovations, and I haven't really STARTED. I've just been collecting parts.
My goal this weekend is to get the Marinco 30A inlet installed so I won't be afraid to plug the trailer in, get the VTS deadbolt installed so I can actually lock the door, and perhaps rip the god-awful 20-gallon residential electric water heater out of the thing.
Photos and updates as the weekend progresses.
— David
Old 07-03-2013, 10:05 PM   #36
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Patiently waiting for some pictures and commentary of the work.
Have fun!
Lance
Top is offline   Reply With Quote
Old 07-04-2013, 11:32 PM   #37
DKB_SATX's Avatar
1976 Argosy 28
Reno work on 4 July 2013
Well, I suppose if things went according to plan I'd be wondering when Murphy would come to visit.
My plan for today was to install a Marinco stainless 30-amp inlet where the "polarity lamp" is currently.
It didn't start out all that badly. I decided that the first order of business should be getting the back window free of the silicone infestation so I could open it, and therefore have a little better airflow for the interior work. UGH! It doesn't look nearly as bad in the photo as it did in person! I must have removed a pound of the crud.
Then, evaluating access to the breaker box and the back side of the polarity lamp, I decided it would be easier to remove the street-side bed so I could get to those areas without destroying the false floor that supports storage bins.
THAT proved to be what sidetracked me. I knew that the previous-previous owner (PPO) had put down lots of OSB with carpet on top in walking areas, and the PO had removed the carpet, screwed that OSB down to the subfloor and put the stick-down tile on the top. What I *didn't* realize was that the PPO covered the hold-down brackets for the bed structure with the OSB, and the PO secured it in place. Ah, well, I was going to do it eventually. I hate stick-down tile, but I wasn't planning on it today.
There's a layer of some sort of leveling gunk over the OSB. It filled every single Phillips screw holding down the OSB so I had to pick it out with a tool before I could put the screwdriver bit into it. Such FUN!
At long last, I freed up the brackets for the bed frame. There's PLENTY of work left for tomorrow. And Saturday. And Sunday, and...
In the process, I discovered that my battery box is probably not trapping hydrogen and directing it out of the trailer as intended. Another new item for the task list!
I also realized that the panel covering the aftmost part of the bedframe is just a piece of semi-matching paneling where one more tambour belongs, and that the aftmost bit of trim is missing. One more esoteric thing to hunt down!
— David
Old 07-04-2013, 11:46 PM   #38
1974 Argosy 20
Kooskia , Idaho
DKB, I did tell you about a nice 31' AS center bath in NM, didn't I ? But Nooooo, you had to have an Argosy. My sympathy is limited.....grin.
Oops, better be nice to him until the real glass front window comes from the donor rig. Then I can snicker more.
Old 07-05-2013, 12:26 AM   #39
Vintage Kin
Fort Worth , Texas
Texas in July is either too hot and too much beer . . or not getting anything done. Wherein lays the balance? The snickers lay on that dividing line.
Old 07-05-2013, 07:15 AM   #40
247stream's Avatar
1986 25' Sovereign
Marietta , Georgia
oh man, I hate it when one project leads to 6 more before you can even do the one you wanted to do to begin with! I feel for ya on that note and the TX heat.
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 07-05-2013, 09:51 PM   #41
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
The worst of it
Ahh yes, Silicone, OSB, and expanding foam. Some of my most hated things I find in vintage trailers.
You are likely to find way more things wrong that you want to find.
Silicone is the worst thing ever to be found in/on an Airstream. I cringe at the thought.
It amazes me some of the things that, at some point, people thought were good ideas.
Keep up the work and I hope things take a turn for the better in the next few days.
Lance
Old 07-06-2013, 06:36 PM   #42
Central , Mississippi
Originally Posted by Top View Post
Ahh yes, Silicone, OSB, and expanding foam. Some of my most hated things I find in vintage trailers...
Silicone is the worst thing ever to be found in/on an Airstream...
It amazes me some of the things that, at some point, people thought were good ideas...
I agree, sillycone..."hey, I only need to seal one part of a leak but I just opened a tube so I might as well use it all..."
Grrrrrrrr...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
restoration
