Originally Posted by SIU Bound
I spoke with Henshen's tech people about my axels. I can't afford axels this year. They told me to put tape in the wheel well and take it out for a test. Pull it and then check to see if I have tire marks on the tape. Henshen said if I did not see any tire marks on the tape and everything else is in good shape the axels were fine. I still plan on getting axels but not this season.
SIU bound
Brian
Brian.
As promised I talked with Jim.
The "tape on the bottom side of the wheel well test" is only to let you know if the tire is hitting the wheel weel.
As far as the axle condition is concerned, that test really doesn't tell anything, other than the tire is not hitting the wheel well.
Torsion axles, develop two problems.
1. The rubber rods can solidify, especially on trailer 1974 and older.
2. The rubber rods give out which lets the torsion or trailing arm to not much if any life left in it to still act as a spring.
When the trailer is empty, if the torsion arm is parallel to the chassis or going upward, the axle is done.
Since torsion axles are weight sensitive, when a pay load is added, the torsion arm will further go upward, again telling you the axle is done.
Just because the tire may not hit the wheel well, does not mean the axle is any good, since the axles also have a built in stop.
All torsion axles will "bottom out" once the parallel to the chassis, or higher, whenever bumps are hit.
That then takes it's toll quickly on the entire trailer and everything in it.
Many posts have been made previous about those problems.
