Old 12-09-2005, 07:11 PM   #15
mtnman's Avatar
Collettsville , North Carolina
Thanks everyone! I appreciate all the input. Tomorrow looks like a good day to work on my coach. I will learn how many water leaks I have. I will also get some LP flowing through that baby and see how many gas leaks I have to repair. This is going to be fun!!
mtnman
mtnman is offline   Reply With Quote
Old 12-09-2005, 08:24 PM   #16
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Window screen - any screen material - just get new spline too (the rubber cord).
And when you get new spline, remember to get a spline tool...
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 12-10-2005, 05:57 PM   #17
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, mtnman,
Hey, go to "User CP" (control panel) and change your "Currently Looking" to "Done Got."
My '75 Argosy 28 appears to have 5/8" plywood in it.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 12-10-2005, 06:26 PM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can get Purple Stuff, or Super Clean, from almost any aouto parts store, I cut it 50/50 with water to clean Vintage Thunder. Which window do you need?
Pm me with the location and size, I may have a spare I can let go fairly cheap.
Old 12-10-2005, 10:43 PM   #19
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I need some stuff
Greetings mtman!
Originally Posted by mtnman
. . . .So here is a list of stuff I need, can you tell me what itís actually called so I wonít sound too stupid when I call it in. Also where can I get it?
7-Door seal for the refer, who and where?
8-I need one window whats is thickness, who and where?
mtnman
While a generic door seal may work for the refrigerator, it would likely be much easier if the seal were OEM or a very similar replacement. The original refrigerator would have been a Dometic. The OEM style gasket may still be available from a number of sources. My suggestion, however, would be to be sure that the refrigerator is actually operable before jumping into gasket replacement. If the amonia-based cooling system is defective, repair can become quite costly.
Since your coach is a Minuet, you might want to verify that the original window material was actually glass. On many of the Minuets, the side windows were produced with a then-modern acrylic material -- my 6.0 Metre Minuet still has its acrylic side windows. The front and rear windows were most often a laminated safety glass product. I have seen so few of the 7.3 Metre Minuets that I am not certain whether they followed the same general mold as the two smaller models both of which frequently were equipped with the acrylic side windows. Some automotive glass shops can be helpful with replacement glass, but my luck hasn't been too good with those in my area -- I usually have my Airstream dealer take care of glass issues when the coach is at his shop for routine maintenance.
Good luck with your projects!
Kevin
Kevin D. Allen
AIR #827
Old 12-11-2005, 06:42 PM   #20
mtnman's Avatar
YES, the refer does work. Man, am I glad of that!
Mtnman
Old 12-11-2005, 06:45 PM   #21
mtnman's Avatar
Originally Posted by SafeHarbor
Hi, mtnman,
Lamar
Hey, thats a great idea!! I forgot, I am an AS owner now!
Where do you shop for Airstream stuff? Andy R Community Polls 60 04-14-2008 02:36 PM
The fancy stuff - Vacuum and Nutone Cheryl Nu-Tone Appliances & Central Vac System 9 10-13-2007 07:59 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
Take this Generator and Stuff It..... kzener40 General Motorhome Topics 8 07-24-2002 07:30 PM
