Old 10-25-2010, 12:55 PM   #1
1976 Argosy 28
Cleveland , Georgia
I need help!
I have a 76 Argosy 28. There is a switch in the middle of the wall above the stove. I can't find what it is for. The range hood controls are in the cabinet so my first guess was wrong. Any help will be greatly appreciated. Mr D
Mr D is offline   Reply With Quote
Old 10-25-2010, 12:57 PM   #2
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
Maybe the water pump???
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 10-25-2010, 01:02 PM   #3
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison , Michigan
Images: 8
You flip the switch and it ejects your mother-in-law!
62bam is offline   Reply With Quote
Old 10-25-2010, 01:20 PM   #4
1976 Argosy 28
Cleveland , Georgia
switch
We have a winner!!!!! My mother in law is great, so I guess I'll keep her. I think the water pump answer is probably correct. I'll have to wait a few days to get back to camp to be sure. Thanks for the help. Mr D
Old 10-25-2010, 01:20 PM   #5
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
If my memory serves me correctly, when the switch is one way you can use the air condtioner. When the switch is the other way you can use the microwave. It is a switch that won't let you use the microware and a/c at the same time.
Charles
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 10-25-2010, 01:21 PM   #6
2010 25' FB Flying Cloud
Davenport , Iowa
is it your battery disconnect switch?
Airtandem is offline   Reply With Quote
Old 10-25-2010, 02:05 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
On our '65 Caravel that switch controls the water pump. On our '83 Excella it is the Microwave/AC switch.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-25-2010, 04:30 PM   #8
1976 Argosy 28
Cleveland , Georgia
I appreciate the replies. My Argosy did not come with a microwave so that is ruled out. The water pump is not being used so I think that is what it is. Thanks, MrD
Old 10-25-2010, 05:25 PM   #9
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
That's where my water pump switch is...
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-25-2010, 08:59 PM   #10
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet Mystery Switch
On the 22 there is a white rocker switch near the fridge vent on the same side of the stove that controls the water pump. What color is it and is it a rocker, toggle, or twist switch, or a photo would be helpful.
If the switch doesn't seem to do anything and your pump doesn't work check the pump fuse at the pump, the 22 had a 5 amp slow blow fuse.
Good Luck
arcamedies is offline   Reply With Quote
Old 10-26-2010, 06:34 AM   #11
1976 Argosy 28
Cleveland , Georgia
My fridge is on opposite side from stove. The switch is a rocker on-off switch. The only thing I have that is not working is the water pump and that is disconnected at present time. I'll check the wire to it. I really think that's what it is. Thanks to all for the responses. MrD
Old 10-29-2010, 06:42 PM   #12
Carson City , Nevada
In my Argy 24 this switch controls the water pump.
Mike S is offline   Reply With Quote
