Old 09-29-2010, 05:56 PM   #21
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
In short, get a new tank. It is cheaper in the long run. When you think of the cost over a 10 year period, it ain't so bad.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 10-17-2010, 09:12 PM   #22
1977 Argosy Minuet 6.0 Metre
Westfield , Indiana
water tank repairs
Originally Posted by Inland RV Center, In View Post
There are a number of products that can be used that sometimes have success in repairing a cracked water tank.
Depending onh the cracks, and the material used, a fix could be short lived or even last a long time.
The big concern, is to "NOT" used any material that could contaminated the water.
Andy, what are some of the products used and which one do you recommend?
DonDiego is offline   Reply With Quote
Old 10-17-2010, 10:00 PM   #23
The best fix is melt the plastic back together, being very careful.
Harbor Freight has an inexpensive plastic welding tool.
Epoxy's won't hold.
Hot glue's will usually fail.
Old 10-18-2010, 07:02 AM   #24
2008 16' Safari
Destrehan , Louisiana
Epoxy's won't hold.
I used the plastic welding kit from Harbor Freight and got good results fixing my black water tank. This is the way to go.
dlb435 is offline   Reply With Quote
Old 09-26-2011, 06:37 PM   #25
Westfield , Indiana
I ended up using the heat/weld method. Using an old soldering iron and milk bottles as welding rod, I made the repair. The big problem was that as the tank heated up, it wanted to drip inward to toward the inside of the tank. It took some time to do, but it seemed to hold.... for now. Not having a high level of confidence in the repair, I then constructed a drip pan out of left over roof flashing. The thought being that should it leak, the drip pan would contain the leak and prevent items from getting wet. Which is my main worry as the floor and everything else is made of Aluminum.
Old 09-26-2011, 07:06 PM   #26
1973 Argosy 24
Pearland , Texas
If you decide to weld it back together just be sure to drill a 1/16 hole at either end of the crack before welding or you will find the crack will continue even after you weld it. I welded mine with a hot iron and some polyethylene pellets and its holding great. (knock on plastic!)
Fujak is offline   Reply With Quote
Old 10-22-2011, 10:52 PM   #27
Air-Texas's Avatar
2004 34' Classic S/O
Stafford , Virginia
I have a 77 Argosy that had the same leak, I also used J-B Weld to repair the tank with only a wet rag wipe down. It has lasted for 5 years ...so far.
Air-Texas is offline   Reply With Quote
Old 10-23-2011, 03:55 PM   #28
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
J-B Weld Repair
The key to the J-B Weld repair is oxidation of the polyethylene surface. Epoxy will not stick to new polyethylene. The surface must be oxidized either by age or flame to achieve a bond.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
repair, fresh water tank
Fresh Water Tank Leak-Now What? ts8501 Fresh Water Systems 8 07-20-2008 12:23 PM
Fresh water tank leak. Devoman Fresh Water Systems 15 12-16-2006 01:51 PM
'66 Fresh Water Tank Leak 66Overlander Fresh Water Systems 3 10-20-2004 03:48 PM
Fresh water tank leak Flex Fresh Water Systems 3 09-30-2004 05:25 AM
Major fresh water tank leak! JohnGalt48 Fresh Water Systems 2 05-17-2004 06:50 PM
