Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Prev Previous Post   Next Post Next
Old 02-26-2004, 06:47 PM   #1
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
How to modify and install rock guard on minuet
We recently installed a Factory Three Piece Rock guard, part number from Inland RV:34977, Airstream number: 695275-100 on a Minuet. Here is a step by step guide to the installation. It’ll take several posts - be patient. If you would like a pdf of the whole process send me a PM. This appears to be a daunting task but with a little patience and help you can do, I did it in less than 5 1/2 hours. The methods I used worked for me and I make no claims and give no warranties that this will work for you. Be careful and work slowly paying attention to what you are doing. Safety first "No job is so important that we can't take the time to do it safely".
1.) Tools needed:
Power Drill [preferably cordless]
Assortment of drill bits
Pop Rivet Gun
Large assortment of pop rivets [Standard Aluminum, not Olympics shave head rivets]
Various screwdrivers [+ and - tips]
Hacksaw [fine tooth blade] (See note 1)
Marking pencil [standard #2 lead]
Tube of Vulkem
Side cutters
2.) Open your boxes from Airstream and inspect the contents, you should have:
Street side and curbside wing guards
Center section guard (with attached hinge and lifting arms)
Bag full of hardware witch should contain
4 hinges, 2 ea. left , 2 ea. right
4 ea Cam-Lock anchors in rubber mount
4 ea. Cam-Lock locking screws
4 ea. Cam-Lock capture washers for the screws
2 ea. Rubber Hood Hold Downs for center section
2 ea. Catch for Rubber Hood Hold Down
a bunch of pop rivets
a bunch of stainless screws
Become familiar with the parts look them over for damage, mine had a cracked side guard I did not see until the paper was removed from the window.
3.) People needed: 1 ea. Good helper. You'll need help from time to time positioning parts as you mount them. Also helps to get your ego stroked every so often.
4.) If you own an Argosy Minuet: you will need to drill out the four pop rivets from the Argosy badge mounted on the front dome. You will have to relocate it in a later step.
Name:	argosy frontal view web.jpg
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is online now   Reply With Quote
