Minuet 6.7 Argosy
Hi! Our 6.7 Minuet with a newer axle. For reference the height to the top of the wheel well opening is 25 in. This will let you make adjustments for axle wear, tire pressure, tire type, etc. From the ground it is 9 ft. 4 in. to the top of the AC shroud (old Armstrong original type AC). From the ground to the top of the front vent is 8 ft. 5 in. Ground to the top of the antenna 8 ft. 11 in. Ground to the top of roof is 8 ft. 3 in. Ours is sitting on a concrete garage floor. We have a 10 ft. overhead door and it goes through with room to spare.
Larry....in frosty Ohio
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
