Old 06-19-2011, 01:42 PM   #1
VonLuck's Avatar
1973 Argosy 26
Burbank , California
How does my fridge work? '73 argosy
Don't know the first thing about my fridge or the system. Can anyone give me a crash course?
VonLuck is offline   Reply With Quote
Old 06-19-2011, 03:45 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It's probably the same fridge I have in my '74 Argosy. There are 2 modes; GAS and ELECTRIC; In order for it to work on gas, you must select the gas mode and obviously have the propane turned on.
In the electric mode the fridge must be plugged in and the shore power must be on.
I've attached a photo of what I think the controls on your unit look like. In the electric mode, set the electric temp setting to at least 5, it will take a few hours to start cooling down.
You also need to make sure the fridge is level. Put a torpedo level on the bottom shelf of the freezer and adjust the trailer accordingly to get the fridge level. These old refers don't operate well when not level.
If you have not had the gas on in the trailer. I find it easier to light the cook top first. The burners on the cook top use a lot more gas and will fill the propane lines quicker. Even at that, the burner in the fridge is pretty small; it will take some time to purge the air from the line feeding the fridge.
If you can not get it lit (in gas mode) by following the text on the photo.
I can show you how to do it from outside.
Old 06-19-2011, 08:50 PM   #3
VonLuck's Avatar
1973 Argosy 26
Hey thank you, Thats exactly the crash corse i needed. Im going to give it a try tomorrow..
What's a 1975 Argosy 26' worth? ValerieW Argosy Motorhomes 8 03-08-2017 10:41 AM
Looking for an owners manual for 1976 Argosy 24' btophek All Argosy Trailers 21 06-08-2014 10:46 AM
Anyone need fridge parts from old Dometic '76 sweetsilver Refrigerators 4 06-24-2011 09:41 PM
Skip the Fridge? (Overlander Newbie) pyrenees Refrigerators 15 05-09-2011 05:30 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
