Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-17-2004, 08:26 PM   #1
1975 25' Tradewind
1986 34.5' Airstream 345
Lewiston , Idaho
Question How Do I get at the shower plumbing
My newly purchased 24' argosy with rear bath has a plumbing leak in the hot water on the shower. How in world do I get at this plumbing without destroying the shower. Any tricks or instructions on removing the shower faucet would be appreciated.
flash is offline   Reply With Quote
Old 07-18-2004, 04:06 PM   #2
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Plumbing
You remove the plastic panel that the fauset is attached too, but first you remove the trim. If the fauset is leaking behind. if the water just don't turn off, the fauset can be rebuilt from the front.
Contact me with more info and I will be glad to help you. I have a 24' and I pulled the complete bath out!! Not fun but can be done.
Don
Gunnyusmc is offline   Reply With Quote
rear bath shower plumbing access PeterH-350LE Airstream Motorhome Forums 6 08-01-2004 07:17 AM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2000 - 2004 Safari 1 09-12-2003 01:28 PM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Shower "door" leak mcostanzo Airstream Motorhome Forums 1 08-11-2003 09:37 AM
