Old 06-06-2009, 09:02 PM   #1
1979 Argosy Minuet 7.3 Metre
Manistee , Michigan
Question Hot Water Heater
Does any one have any thoughts on what make Hot water heater I can install in my 7.3 minuet. The unit must be 110volt electric
Thanks all
Dave G.
Manistee, Mi
Dave G. is offline   Reply With Quote
Old 06-06-2009, 09:10 PM   #2
Thanks all
Dave G.
Manistee, Mi
Dave.
There are several good brands of water heaters. Atwood and Suburban are a couple of the top names familiar to Airstream owners.
By the way, Airstream and Argosy trailers and motorhomes, never used "hot water heaters."
But they did use "cold water heaters."
Old 06-06-2009, 09:12 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Why on earth would anyone need to heat hot water?
I've seen many Atwood water heaters, standard 6 gallon type would most likely work.
Old 06-06-2009, 09:24 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Minuet Water Heater
Greetings Dave!
Welcome to the Forums and the world of Vintage Minuet ownership!
My suggestion would be to consider a dual fuel water heater if you must have the electric option. If you plan to do much traveling with your Minuet, I am afraid that you might regret having an electric only water heater. Despite my dislike of LP or natural gas appliances, I went with a relatively standard Atwood 6 gallon propane only model with the standard pilot light for my Minuet (my dealer advised me that it was a near direct replacement for the original water heater). It is quite efficient and has been comparatively trouble-free over the past five seasons.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
My hot water heater Mirthless Water Heaters, Filters & Pumps 2 03-14-2009 05:34 PM
Need New Hot Water Heater bullydogsmom Water Heaters, Filters & Pumps 11 03-01-2009 02:10 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot Water Heater ?????? davidh Water Heaters, Filters & Pumps 7 02-28-2006 07:25 AM
hot water heater 53flyingcloud Water Heaters, Filters & Pumps 4 07-08-2002 10:18 AM
