Old 11-16-2013, 04:07 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Hot water bypass
I'm trying to drain the tanks and lines in my 26 foot Argosy. PO had written on inside wheel-well "to bypass hot water close rear two taps and open front tap". There are 3 valves off the hot water tank (2 up top and 1 on bottom). In the back closet where my battery sits there are 2 valves back there that already appear to be in the closed position yet I ran hot water last time out.
I'm not sure which they were referring to?
Any thoughts?
Thanks.
Dan
ID:	200144   Click image for larger version
Dan S is offline   Reply With Quote
Old 11-16-2013, 05:16 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
There are two pipes coming out of the water heater. Follow those two lines from the water heater back to the first valve you come to on each. Close those 2 valves and open the third.
Old 11-16-2013, 08:59 PM   #3
1973 Argosy 22
Shepherdsville , Kentucky
On my 22" Argosy the valves near the battery box are drain lines.
Tom S. is offline   Reply With Quote
Old 11-16-2013, 09:10 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe the valves with the red handles are the drains. The blue handled valves are the bypass system.
Old 11-17-2013, 04:22 PM   #5
Dan S's Avatar
1975 Argosy 26
So I've diagramed it out and I believe I now understand it assuming the top port on the hot water tank is the exit for heated water and the lower one is the inlet for cold. Does this look correct?
The red valves were drains, thanks.
Dan
Old 11-17-2013, 04:38 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
That looks correct.
Old 11-17-2013, 04:52 PM   #7
Dan S's Avatar
1975 Argosy 26
Thanks.
