| 6.7 m. Minuet 1978 Argosy
The gray tank in our Minuet is above the floor which places it above the drain in the shower. The shower drain ties into the sewer drain downstream from the tank valves and exits through the coach's sewer drain to a blue tote, (or into the sewer outlet). In the glory days of the Minuet it was acceptable to let the gray water go on the ground, therefore it DID NOT go into the gray tank.
Lou and Larry
__________________ Larry and Lou CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction! Air #2695 TAC- OH 2 #1420 NOVA 4-006 Charter member |
