Old 11-18-2009, 04:45 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Hitch Balls and Wheel Bearings?
Are wheel bearings specific to the size wheel? Does one wheel bearing fit all 14's...etc. I don't assume they are brand specific. Also, what size ball do I need to tow a 73/74 20' Argosy? Thanks!
Roadrunner is offline   Reply With Quote
Old 11-18-2009, 05:57 AM   #2
SteveH's Avatar
Common Sense , Texas
Wheel bearings are sized by the weight capacity of the axle....more weight, the bigger the bearings.
You will need a 2 5/16" ball for your Argosy.
Old 11-18-2009, 09:27 AM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
Hitch Ball
Hitch balls have the maximum weight to be towed.
Make sure that you get the 2 5/16 ball with a weight rating for more than your Argosy weights.
I just got the heavest rated ball I could find (14,000lbs).
Beginner
Beginner is offline   Reply With Quote
Old 11-18-2009, 02:15 PM   #4
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
what do you mean by brand specific?
bearings are spec'd out like so many things, but they do not exist before an application creates those spec's. So when a manufacturer creates "something" that needs wheel bearings, they take into consideration all the engineering data and seek out a bearing/axle/drum(rotor) combination that will all work together. So, what the mfg of the "something" specifys a particular bearing, it is brand specific. But, it is a bearing class, not mfg specific-the bearing can be mfg by anyone as long as it meets the specifications placed on that particular bearing. Sometimes a single bearing MAY only be made by one mfg. Other times, demand causes more than one mfg to build the same bearing.
But, AS determines what bearing your outfit needs, so a contact with them is in order. that contact can be direct, or via a dealer, or via a manual, or perhaps a parts supplier application catalog.
'ol bill
wmarsha is offline   Reply With Quote
Wheel bearings Allen H Axles 18 10-31-2007 04:12 PM
Wheel bearings FlyingW Axles 3 07-01-2006 05:36 PM
Wheel Bearings 76ArgosyDave Axles 7 06-29-2005 03:00 PM
Wheel Bearings 85MH325 Axles 5 04-05-2004 06:41 AM
Speaking of hitch balls Ken J Hitches, Couplers & Balls 11 10-18-2003 09:09 AM
