Old 04-27-2007, 08:07 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Help- leak in black tank (photos)
After seeing a leak in a access panel that appeared directly underneath the toilet, someone suggested it was probably due to bottoming out and creating a break and or crack the the line.
Here are a couple shots of where the access panel is (PO installed) under the junction between the black water tank (actually blue in picture) and the drain line.
I had previously noticed water dripping from this access panel and decided to unscrew it. There was pink insulation around the pipe and it was "muddy". I quickly tossed that part out and washed up. Since I don't have much ground clearance, it's hard to poke my head up in the cut out to see much.
I'm guessing the best way to trouble shoot is to fill the gray and black tank or flush and see if a leak is noticable....any suggestions? If I do see it, I'm guessing I'll have to cut a much bigger access panel as well.
ID:	36297   Click image for larger version
Name:	crop septic.gif
Dan S is offline   Reply With Quote
Old 04-27-2007, 08:11 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Suggestion? Yes. Fill one tank at a time, there's no need to add to your confusion by filling both at once.
Also, put the tongue jack all the way down (up) so the nose is down, you will have more room to work. Also, if you still don't have enough room to work, you can back your trailer up on 3 or 4 2x6's to add to ground clearance. Once you can fit under the trailer, you can see where the leak is coming from.
Old 04-27-2007, 09:36 PM   #3
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
You may need to drop part of the belly pan to isolate the leaking area. We had a gasket leak in the black tank. The symptoms were water was leaking from around the drain pipe (our pipe looks just like your photo) but it could be coming from anywhere. Once we dropped part of the belly pan, we were quickly able to zero right into the leaking gasket.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 04-28-2007, 07:58 AM   #4
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Be sure to check the neck of the tank carefully. Those tanks can and do fatigue and cracks in the neck mean a new tank. The valve may need replacement or rebuild as it has gaskets that can deteriorate. And, yes, you are in for better access to the area. Take the belly pan down to get enough room to work in there. None of this is rocket science, just messy.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 04-28-2007, 02:53 PM   #5
Dan S's Avatar
1975 Argosy 26
When everyone says "take down the belly pan" are you suggeting I drill out all the rivets holding it up and removing the entire piece front to back? Or, just cut out specific sections?
Dan
Old 04-29-2007, 06:47 AM   #6
yukionna's Avatar
Massachusetts
Images: 18
Yes, you will be drilling them out. You only need to remove as many rivets as it takes to expose the area you are interested in looking at. The rivets are easy to put back with a rivet gun and rivets. To drop the belly pan, start at the area of the trailer where the black tank is located.
For our black tank, we only needed to drill out a dozen rivets to expose the black tank.
WBCCI Region One
Old 04-29-2007, 07:02 AM   #7
Well Preserved
1993 21' Sovereign
Just be sure to use aluminum rivets to reinstall the belly pan. Our Overlander had steel rivets in some places on the belly pan, they will rust and contribute to dissimilar corrosion issues.
Old 04-29-2007, 10:27 AM   #8
Dan S's Avatar
1975 Argosy 26
Why not cut a larger access panel? I've seen several threads (both here and the main Airstream one) suggesting a cut out. If I recall, the pan, for the most part, was one continious piece, I don't recall it sectioned off.
Dan
Old 04-29-2007, 12:05 PM   #9
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Why not cut a larger access panel? I've seen several threads (both here and the main Airstream one) suggesting a cut out. If I recall, the pan, for the most part, was one continuous piece, I don't recall it sectioned off.
Dan
Dan
Cutting a small hole works but I hate to work through a hole in this situation.
On your Minuet I found that forward of the rear bumper about 4 or 5' there is a cross member under the belly pan. Look for the rivet line and cut side to side with a cut off wheel. Make sure your cut has enough meat left to pop rivet the belly pan back in place. then seal with Vulkem or like sealer. You will need to drill a few pop rivets in the bumper box and remove the bumper bolts, then slide the whole section forward to remove it. It took me about an hour to remove the section of the belly pan but is was well worth it. On a Minuet it is very tight where you'll need to work and having the room is nice. I also found a cracked drain pipe from the kitchen after it was exposed.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-29-2007, 01:27 PM   #10
yukionna's Avatar
Massachusetts
Images: 18
Cutting a larger access panel is an option too. It is just an option I personally would not choose as our belly pan dropped quite nicely in the back.
WBCCI Region One
Old 05-01-2007, 06:30 PM   #11
1973 20' Argosy 20
Vancouver , B.C.
Its easier to pop the rivets by drilling them with a 3/16 drill than it is to cut holes in the metal.
Vancanargo20 is offline   Reply With Quote
Old 05-02-2007, 07:34 AM   #12
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Another thing you can do is fill both the black and grey water tanks with water along with different color food dyes. I did this and it told me immediately where the problem was.
wacnstac is offline   Reply With Quote
Old 05-06-2007, 05:18 PM   #13
Dan S's Avatar
1975 Argosy 26
I took the easier way, for me that is, and took the trailer to a guy that has a small RV shop here in Seattle. I'm hoping he has it done by this next weekend so we can finally camp in it for the first time.
Dan
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 06:11 PM
Cat's FIRST Photos of BEARs progress Cat General Interior Topics 3 11-13-2002 09:46 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Water Tank???????? TheBigRedTruck Fresh Water Systems 3 06-14-2002 10:11 AM
