Old 05-24-2015, 08:24 PM   #1
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
Help! Just starting renovation of 1977 6.7 Minuet
I recently purchased an 1977 Argosy 6.7. Lots of funky stuff was done to her, so I'm begun to gut her.
first question. I need advise on the floor. I removed the old carpet, and aluminum floor was exposed. Can I add 1/2" plywood then floor covering. Or what? I'm open to suggestions.
second question. Can I take her to all electric? and if so, what panel box would you use?
paddle whisp is offline   Reply With Quote
Old 05-24-2015, 08:24 PM   #2
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
3rd question... what paint should I use on the inside?
walls?
cabinets?
Old 05-24-2015, 09:22 PM   #3
kootenayken's Avatar
1976 Argosy 22
cranbrook , British Columbia
I have pulled up a few carpets and always found plywood? If you are going to park it, 120 v is an option but if you are going to travel in it you are limiting your destinations. Electric hookups are not always available, before a major renovation I would take a look as to how I intend to use the trailer.
kootenayken is offline   Reply With Quote
Old 05-25-2015, 06:51 AM   #4
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Most but not all Minuets came with aluminum subfloors. If you are planing to tow it places, adding the plywood will add weight. When adding weight, consider overall gross as well as tongue weight. If I was to guess why you want to add plywood it would be because of the aluminum floor having cross beams about every 4 feet. The floor dips between the beams giving you that uneven wavy feeling. Adding plywood should eliminate that. 1/2 inch will still flex with the 4 foot span. You would have to shim the center which may help some.
I added a cheep snap together laminate floor. I first put down the foam pad. Trying to fill in the dips for a more level floor I put down 2 foot wide strips, going the width of the trailer, down the center of the dip. Then a 3 1/2 foot on top of that. Then I ran my flooring length wise. Most people don't notice any unevenness. I do, but maybe because I know it's there.
Going all electric limits you to campsites with electric or running a generator. Some campgrounds don't allow generators.
It also may effect the resale.
The 120 volt system in a camper (outlets, A/C, microwave, etc) is the same setup as your house. So the same circuit breaker box as your home.
The lighting is 12 volt. Run by a battery or a converter. If you go all electric, you could keep the 12 volt lighting run by the converter.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 05-26-2015, 08:59 AM   #5
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Laminate floor is a good idea in the aluminum floored Minuets. Use throw rugs. I don't notice the dips in the floor with laminate and it does distribute the your weight over the aluminum. As for all electric, why? The market for Minuets is a lightweight unit that can be towed with ordinary vehicles. The vintage aspect also helps. As pointed out above, all electric limits your choice of camp sites and hurts the resale somewhat. Having said that, I would just tell you to do what you think is best. It is your trailer.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 06-11-2015, 08:02 PM   #6
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I received a total repair and paint bid today, using metalic auto paint by a body shop. $3200. for exterior and $800. for the interior.
Is that reasonable?
Old 06-11-2015, 08:13 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
That is reasonable for a good job. Top notch prep and paint work ain't cheap...Have you looked at some of the shops work?
CRH is offline   Reply With Quote
68 ambassador bathroom starting point - bathroom renovation hedgerocks Plumbing - Systems & Fixtures 1 03-18-2015 03:55 PM
Full renovation starting on 1969 Ambassador OrlandoNewb 1966 - 1969 Ambassador 4 01-21-2014 11:35 AM
Help, need measurements-1977 6.0 Minuet vcu70 All Argosy Trailers 1 04-10-2010 10:11 PM
1977 land yacht 31 vs 1977 argosy minuet 20 joe77 General Interior Topics 3 06-30-2009 08:51 PM
starting a renovation 58overlander General Interior Topics 4 01-04-2005 07:10 AM
