Old 06-24-2014, 08:29 AM   #1
1988 29' Argosy
arlington , Texas
height clearance
What is the height clearance of an 1988 Argosy 29' with roofmounted A/C? Im trying to see if trailer will make a parking spot at the new deer lease....
thanks for the help.
cl
cl1395 is offline   Reply With Quote
Old 06-24-2014, 09:45 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Figure 10' for planning purposes. If it's close you should measure the actual trailer.
The clearance on my 2010 classic was supposedly 9' 7.5" when new, and that's with low-profile A/C. Most trailers are very close to this. Tires, axles, and differences in air conditioner height can each lead to changes of a few inches. Low profile A/C is 9.5" high. Standard is 12.75". You can lose half an inch if there's a double gasket.
It's difficult to measure clearance accurately, and even if you do, suspension travel, hitch height, and uneven ground can cause you to hit stuff that the clearance measurement says you would miss. Be careful.
Old 06-25-2014, 02:47 PM   #3
1988 29' Argosy
arlington , Texas
Thank you for the info
Old 06-25-2014, 03:00 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have a 1975 and 1981 both will clear a 10' door... barely.
Aaron
WBCCI #XXXX AIR #2495
Old 06-25-2014, 04:08 PM   #5
1977 Argosy 24
Milltown , Wisconsin
My 77 Argosy 24' fits in my shop with a 10' door with room to spare.
ventport is offline   Reply With Quote
Old 06-26-2014, 10:59 AM   #6
1988 29' Argosy
arlington , Texas
Aaron
Thank u for the info
Old 06-26-2014, 03:32 PM   #7
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
For what it is worth, my 12' x 14' garage door is set to open only to 10' - 1" and the 2015 Serenity 30 RB with two A/C units goes in with what looks like about four or five inches of clearance. This is from a level drive to level garage.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-26-2014, 04:05 PM   #8
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
11 FOOT 8 — The Canopener Bridge
Old 06-27-2014, 08:38 AM   #9
1988 29' Argosy
arlington , Texas
[Thank you
Hitch height Chuck Hitches, Couplers & Balls 20 04-09-2016 10:21 PM
Airstream Height Earl Winterizing, Storage, Carports & Covers 25 03-22-2008 08:34 PM
Airstream height Earl 1981 - 1983 Excella 1 09-01-2003 09:35 PM
tow hitch height using a 1960s car oldvws Hitches, Couplers & Balls 15 11-27-2002 03:43 PM
Hitch height help daydreamer36535 On The Road... 4 09-28-2002 01:11 PM
