Old 01-01-2013, 04:10 PM   #1
BJH
1974 Argosy 24
Springtown , Texas
Question Hatch Light
Can the hatch light bulb on a 74 Argosy be replaced by removing the little plastic covering on the front?
BJH is offline   Reply With Quote
Old 01-03-2013, 10:04 AM   #2
rogerdodger's Avatar
Fresno/Clovis , California
If you mean the light over the front door, I think you need to remove the screw holding the assembly, located at the top, unless, like mine, there is no plexiglass lens, then the access is thru the front.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 01-03-2013, 10:14 AM   #3
BJH
1974 Argosy 24
Springtown , Texas
Thanks Rogerdoger. Yeah its the front door. I climbed up and took a closer look and it appears that you are right, looks like I'll have to take out those two small screws. We'll see what happens after that. Thanks again.
Old 01-03-2013, 10:32 AM   #4
1974 Argosy 20
Kooskia , Idaho
The little steel screws will most likely be rusted/corroded into the cast Al light cover. Another stupid design error, but one we have to live with. Best of luck removing them.
Old 01-03-2013, 11:37 AM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
replace the screws with stainless. I had to grind off the screws on 2 out of 3 over-door lights to get them off. Z
PS--don't forget the third screw towards the back edge.
Old 01-03-2013, 11:50 AM   #6
BJH
1974 Argosy 24
Springtown , Texas
Thanks for the help guys, theres nothing like the voice of experience
