Old 09-13-2010, 01:04 PM   #15
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
biggoofball's right. Take your time now. I also bought a very nice nearly original Argosy - and then wound up investing the same amount in upgrading it and replacing stuff (like the axle.)
As an aside, I'm jealous of whitefawn's 78 Argosy 24 - if we ever buy another Argosy, that's the sweet spot for us...
Tom
mutcth is offline   Reply With Quote
Old 09-16-2010, 10:06 PM   #16
sharbours's Avatar
1975 Argosy 24
West Linn , Oregon
Images: 11
Originally Posted by whitefawn View Post
We just bought a 1978 24' Argosy and we hope this will be the right Airstream when we get through with it. We will be enlarging the dinette and enjoying the view from the dinette with those great front windows. Good luck on your new quest.
Kathy
Kathy - I'd love to see your ideas for remodeling your dinette! We'd like to do something similar, maybe a U-shaped seating area? Anyway, we're always looking for inspiration, if you don't mind sharing your thoughts.
Jim, good luck in your search for your perfect trailer! You'll know the right one when you see it. Skip is right, though - even if you find one in near perfect condition, there will always be something that can be fixed, upgraded, replaced, etc. I find that part kind of fun, actually!
Sharon
Sean & Sharon
AIR #: 27389
TAC #: OR-3
sharbours is offline   Reply With Quote
Old 09-19-2010, 04:22 PM   #17
Whitefawn
whitefawn's Avatar
1978 Argosy 24
Scottsville , Virginia
The never-ending-story
Sharon-
Our plan for the dinette is as follows: on the side next to the kitchen counter, we are extending the dinette all the way to the kitchen counter. Right now there is a furnace vent on the sidewall of the kitchen counter pointing to the sidewall of the dinette and several inches of wasted space between them. The vent will have to be rerouted. On the door-side of the dinette, we are extending the sidewall of the dinette nearly to the edge of the door opening, which will also give us several more inches of dinette. Also, we are building-in storage space behind the dinette back walls, that will accommodate a couple wooden folding chairs that fold flat to a couple inches thick, and any other flat or rolled up stuff that we might carry such as stadium chairs.
I have toyed with the U-shaped concept, but practicality and the need for storage space wins. We are still tinkering with ideas, but will probably have the area above the fresh water tank accommodate our long, rolled up outdoor rug that we place outside while camping. I will be making a cover that matches the upholstery fabric I bought for the project, so that when not in use, it will blend in, below the curtains I will be making.
We bought some beautiful used Corian from Craigslist, and hope to make it work for the dinette table. We are planning to put two flush-with-floor- pedestal mounts to support the table top with pedestals, which will be longer than standard to accommodate the wider dinette. We are still trying to decide if the table top will also work as the drop-down foundation for the bed. If not, we have the challenge of where to store the table top and bed foundation respectively when they are not in use (possibly behind the dinette in one of the storage compartments). We are unsure if the weight and strength of the Corian will lend itself to these ideas when cut to the desired size, so we will be winging it as we go. We will be building lift-up hatches for under the dinette seats-- storage is ever on my mind.
We are finishing some household and yard projects before we tackle the Argosy makeover this winter. We plan on posting photos of the makeover as we go. Right now the Argosy is torn apart, patiently awaiting our attention. I sent the stove top out to be re-chromed, and we are doing miniscule things- replacing light fixtures and stereo wires and components so we have tunes when we tackle the big stuff. We have almost all of the supplies we need. Will keep you posted. Truly- the dinette was the driving force behind getting rid of our 1971 Overlander and getting the Argosy, so it will somehow be a masterpiece when we are done!
Kathy
whitefawn is offline   Reply With Quote
newbie questions LeisureTime Our Community 14 07-20-2008 02:56 PM
A newbie with questions ciquing Member Introductions 12 11-17-2006 01:00 PM
Newbie w/questions Peter&Denise Hitches, Couplers & Balls 13 04-15-2005 09:01 PM
Newbie Questions RVNUTTY Electrical - Systems, Generators, Batteries & Solar 5 02-29-2004 08:52 PM
Newbie with questions Tin Hut Axles 11 08-21-2003 06:10 PM
