Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 06-17-2011, 09:07 AM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Furnace out-need help before we leave
Got propane, turn up the thermo but but nothing happens, no click....nothing
Any ideas. We wanted to head out today in about 5 hours
Dan
Dan S is offline   Reply With Quote
Old 06-17-2011, 09:12 AM   #2
Dan S's Avatar
1975 Argosy 26
Forgot to mention:
It's a Duo-Therm model 90125.001
The only adjustment or control i see after i remove the panel Is a burner air adjustment screw visible, can that in anyway help.
Old 06-17-2011, 09:25 AM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
You could always head this direction... spend a few days in Texas right now and you'd be contemplating removing the furnace for extra storage space.
— David
Old 06-17-2011, 09:32 AM   #4
Dan S's Avatar
1975 Argosy 26
It will be in the 40's in the mountains just out of Seattle this weekend
Old 06-17-2011, 09:38 AM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Dan
There should be two wire running to the Furnace. Blue in color normally. Short them together and see if the fan runs. If the thermostat is old. It has a mercury switch with small wires. They could have broken.
You should also have a fuse inside the furnace accessable from the outside.
Michelle TAC MT-0
Sarah, Snowball
Old 06-17-2011, 05:17 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Questions
Is this the original furnace? If so you need to set the thermostat all the way to the left and light the pilot.
If you have done that; does the pilot stay lit?
Make sure you have 12 volts DC to the furnace.
If not; check the fuses.
Does the blower run when you set the thermostat to max? Even when there is no flame?
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
Stove & furnace for Bambi II Becky B. General Appliance Topics 4 03-26-2011 08:23 PM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
furnace wont run with dust cap on steven2themax Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-01-2011 06:41 AM
