Originally Posted by tarnished
I'm on the road using an iPad. Will get to a library if I need to download a print copy. The only power source I want is the 110. Very rarely will I need 12v or gas.
It blows the 30 amp fuse in the main breaker box.
Thanks for the replies will be working on them in an hr or so.
Paul
The blown 30 amp fuse will likely have nothing to do with the Dometic refer.
But it's easily checked.
Unplug the Dometic. Plug into 30 Amp.
Does the breaker/fuse hold?
Plug in the refer. Does the breaker trip (or fuse blow)?
You probably have something else going on.
So, run the refer on propane until you solve the 30 amp issue.
You can run on propane as long as you have
12 Volt DC from the batteries to run the refer control panel.
Hope this helps.
Ask specific questions if you like.
