Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 07-17-2004, 08:21 PM   #1
1975 25' Tradewind
1986 34.5' Airstream 345
Lewiston , Idaho
Question Front window cover needed
Just purchased a 1975 24' argosy. I would like to purchase a window cover for the front wrap around windows. Any information on dealers selling this cover would be appreciated.
thanks
Patrick
flash is offline   Reply With Quote
Old 07-17-2004, 08:44 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Curtain?
thanks
Patrick
Are you looking for a curtain to cover the window from inside, or a snap on cover to go over the outside of the window?
guy99 is offline   Reply With Quote
Old 07-18-2004, 12:45 AM   #3
i think he means the exterior "bra" that protects the windows while you travel- I also am in need of one
and dont want to spend a wad of cash on it
eaglerab is offline   Reply With Quote
Old 07-18-2004, 06:03 AM   #4
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
My Avitar
Is the window cover on my Limited, see my Avitar, the one you're looking for?
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
https://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - https://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 07-18-2004, 06:57 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
C'mon! A harder question please...
For the DIY-ers the gold-standard of posts is http://www.airforums.com/forum...ead.php?t=9638
Kevin Allen (Overlander 64) has rather complete info on Minuets and Argosy in other threads -- The Minuet may be 6" narrower than the Argosy so figure accordingly.
5 meter Langford Nahanni
Old 07-18-2004, 12:38 PM   #6
Retired.
. , At Large
It might be tough in Idaho, but try to find a sailmaker, or canvas shop, to make one for you. They are not that expensive.
Old 07-18-2004, 04:02 PM   #7
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Window cover ( Rock Guard)
thanks
Patrick
Inland RV has them. I have a 24' Argosy and the last time I priced it was $635.00.
Don
Gunnyusmc is offline   Reply With Quote
Old 07-18-2004, 05:35 PM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Patrick!
Welcome to the Forums and the world of Vintage Argosy ownership!
thanks
Patrick
The rock guard for the Argosy coaches is the same one used for Airstreams with the similar deep-warp wing windows. The one exception is for the Minuets - - the wing windows are the same but the center window is narrower due to the narrower width of the Minuet.
There were two types of rock guards typically used on Argosys - - the canvas or vinyl covers sewn to the dimensions of the windows and attached to the exterior of the coach with snaps. The second is the three-piece hinged cover that is a current Airstream part. The modified three-piece rock guard installed on my Minuet can be seen in the photo below:
As has been mentioned by others posting replys you can expect the cost for a new rock guard to be in excess of $600.00 (the cost will be somewhat dependent on location in relation to the shipping point as the package is rather bulky). The last time that I checked, the cost to professionally replace one of the wing windows approached $500 and the new replacement windows are no longer available in clear - - solar gray tinted was the only choice. This is one of those items that you may be able to source from a salvage yard such as Colaw's RV Salvage in Carthage, MO. You can find Colaw's at:
Colaw's RV Salvage
Good luck with your search!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
67 Tradewind window part needed JimC Windows & Screens 9 11-27-2009 10:27 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
front window adjustment jackt Windows & Screens 2 03-18-2004 05:36 AM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 04:25 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
