Old 05-19-2016, 06:50 PM   #1
1973 Argosy 26
Carmel , California
Fresh water door lock
Hi,
Is there an available replacement for the lock cylinder(I've seen replacement keys) for the fresh water door? I'd like to secure that. Also wondering if all the doors were keyed alike?
Thanks!
-Chad
air:104541
ChadC is offline   Reply With Quote
Old 05-19-2016, 07:37 PM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Just replace the complete local, they shouldn't be much.?
Old 05-19-2016, 07:50 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Those locks are readily available on Amazon for $11. Generally all of these lock take a 751 key. This is the same on all RV's
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 05-19-2016, 09:28 PM   #4
1973 Argosy 26
Carmel , California
Thanks for the replies! I appreciate it!
-Chad
air:104541
Old 05-19-2016, 10:40 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It's non-trivial to replace the lock in the water-fill door of an Argosy trailer if the one you have is currently locked. I think it might not be so bad if it's unlocked.
At any rate, it's NOT the 751 key if it's the original lock, it's a "double-sided Illinois" key and the replacement I bought from ODMRV says "IL-1" on it, I believe.
ODMRV calls it a "WF-01" in their web catalog.
Mine was locked and I took it to an old locksmith who had probably been a locksmith longer than I'd been alive (which was 45 years at that point) and he immediately recognized the keyway but didn't have any blanks. What he told me about the keyway helped me find the key at ODMRV.
— David
Old 05-20-2016, 05:34 AM   #6
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Standard cabinet hardware. I got mine at Home Depot for less than $8.00
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-20-2016, 08:03 AM   #7
1973 Argosy 26
Carmel , California
Awesome. Appreciate the info. Currently, there is no lock installed.
-Chad
air:104541
Old 05-20-2016, 10:31 AM   #8
Lovin' the Mountains
2015 25' Flying Cloud
Pine , Colorado
My sense is that all of those doors are keyed alike. My present 2015 Flying Cloud 25' FB uses the same key as my former 2010 model. Moreover, this key (CH751) is so common it can be ordered from E-Bay at $3.50 per pair.
tomsos is offline   Reply With Quote
Old 05-20-2016, 10:48 AM   #9
2007 22' International CCD
Meh. I installed a shiny new irrigation controller at home. It came with a CH751 key. They are everywhere!
Old 05-20-2016, 01:41 PM   #10
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
My Argosy has different keys for the water, battery and access refrigerator doors. Someday I will re-key them alike. They are basically standard cabinet door locks which are available at any hardware store or locksmith shop.
If you are installing new or replacing an existing lock, check the thickness of the lock as some may be too deep. You may also have to re-use or modify the bent metal locking bar that screws onto the back as these come in various configuration to fit different thicknesses.
The locks are not hard to take off. If you want all your access doors keyed alike, take the locks to a locksmith and they can either re-key the existing or provide new locks all keyed alike.
rvb is offline   Reply With Quote
Old 05-20-2016, 08:16 PM   #11
1973 Argosy 26
Carmel , California
Great info, glad there is so much good help here.
-Chad
air:104541
Old 05-20-2016, 09:25 PM   #12
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . if everyone in the campground has same locks / CH751 key for storage compartments, water, etc, doesn't seem to make much sense worrying about locking them. . . just sayin (had mine rekeyed). . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 05-20-2016, 10:14 PM   #13
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I misplaced the key to mine once. Opened right up with the awl type blade on my pocket knife.
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 07-22-2016, 06:53 PM   #14
1976 Argosy 26
Henderson , Kentucky
Images: 14
water/access door re-key solution
Just call locksmith. Mine was locked and key misplaced. They can jiggle a blank in the lock to rub the outline on he blank then file out to cut an original for the lock. cool to watch and easy.
Ky76Argosy is offline   Reply With Quote
1964 fresh water tank fill cap lock Safari64 Fresh Water Systems 0 06-25-2013 12:30 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Fresh water lock help? adamgraves Doors & Locks 15 03-26-2012 09:20 AM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
Safari 23 SE - lock fresh water intake? TheThreeSeas 2006 - 2010 Classic (all lengths) 16 02-07-2007 05:03 PM
