09-09-2006, 07:41 AM
1976 26' Argosy 26
St. Albert
, Alberta
Free Argy Interior Parts
Hi all. Tomorrow I'm taking apart the Argy 26 interior. If there's anything you want, it's yours free, I'll take extra care removing it and put it aside. Just the UPS shipping charges. Appliances are coming out too...everything right down to the wood!
09-09-2006, 03:45 PM
1982 34' Limited
1975 31' Sovereign
Grovetown
, Georgia
Your coach looks like it is in very good shape. Seems a shame to gut it.
09-09-2006, 04:40 PM
1978 Argosy Minuet 6.0 Metre
Madison
, Wisconsin
Argosy Parts
Hello Chopper,
We would be interested in your two louvered cabinet doors if they measure 34and 1/2 inches.
Let us know and good luck with your project.
Pat
09-09-2006, 06:14 PM
1976 26' Argosy 26
St. Albert
, Alberta
Louvered doors
You are welcome to them, can you describe it a little better so that I can take pictures tomorrow when I'm out there (also so that I can remove them with more care). Do you mean the uppers?
Cheers!
09-09-2006, 06:19 PM
1976 26' Argosy 26
St. Albert
, Alberta
Condition of Argy
Hi GoBob!
At first (and because we were happy in our current unaltered original '73 Boler 17 but it had gotten too cramped in there with growing kids) I wanted to keep it all original too, but I'm really worried about the floor after a lot of the posts I see here and in light of the funky mildew smell in there. I'll start with removing the carpet as my plan is to do a cork floor, and if the floor is ok then I'll have more of a restoration option as opposed to the rebuild option. I'll post some pictures tomorrow of what I find. Plus...it's a bit of a hodge podge of PO attachments and as I have no idea of the history of the unit...well, let's just say that right now, it's a little "heavy" with age.
Cheers!
09-09-2006, 07:11 PM
Madison
, Wisconsin
Cheers!
Yes, the two above the front couch/bed in the photo you posted. Are there others in your unit? We may be interested in them also. We would also need the "snail" tracks. Thanks so much, and let us know the shipping charges when you get them ready. You may e-mail us directly at pjkmifflin@sbcglobal.net.
Dave and Pat/Madison, WI
09-09-2006, 07:29 PM
1982 34' Limited
1975 31' Sovereign
Grovetown
, Georgia
Pull the carpet out tomorrow and let it air out and wipe down interor. THis should get rid of the mold and mildew problem. Usualy caused from keeping the trailer closed up. Most minor flooring problems can be patched fairly easy and a lot less costly that a gut on such a nice trailer. At 30 your AS is not even middle aged.
09-09-2006, 07:51 PM
1976 26' Argosy 26
St. Albert
, Alberta
Middle aged AS...
GoBob...not middle aged yet for an AS...That's a good one! To follow up on the analogy, I'd say that this Argy is about to go through a mid-life crisis and may end up colored a hot Candy Apple Red and be zipping around like a youngster again!
However, first things first, I'll do the rehab on the carpet and subfloor. If you see my pics on where I found the Argy, it's was at the very very very back of the lot right next to a trashed Travelair...that's how much respect they were showing it. And I'm a little suspect on the "just came in at the beginning of the season" bit 'cause the tires were pretty much sunk in!
09-09-2006, 08:11 PM
1976 26' Argosy 26
St. Albert
, Alberta
Gone already are...
Hi, the fridge and oven (if it works tomorrow...haven't tested any mechanicals yet) may be spoken for. As well, the louvered (tambour) doors and tracks from the upper fronts are requested. I'll answer the PMs in the forum so you can track what's gone.
Cheers!
09-10-2006, 05:30 PM
1975 Argosy 26
Covington
, Louisiana
Free Argy Parts
Hi Chopper
We have a 26 Argy need bathtub, hoping yours is still available.
09-10-2006, 07:51 PM
1976 26' Argosy 26
St. Albert
, Alberta
Ok, tub is yours, photos on Tuesday
Hi, just in time...tomorrow night we take apart the twin beds and the bathroom. I'll post pics tomorrow night on what it looks like for you.
Cheers!
09-10-2006, 09:19 PM
1976 26' Argosy 26
St. Albert
, Alberta
Fridge and stove pics for Funchucky
Hi, here are the stove and fridge pics. Again, I'll either test them in situ or take them out and the nearby AS dealership should be able to qualify them.
Cheers.
09-10-2006, 09:29 PM
1976 26' Argosy 26
St. Albert
, Alberta
Water pump and front tank
The pump is out, and the water tank sure looks grimy inside. I think I'll replace it.
Cheers!
09-10-2006, 09:33 PM
1966 26' Overlander
Waskom
Hello Chopper,
I recently traced a strong mildew/ musty smell in my 1966 Overlander to the old padding under the carpet. The problem became noticable and got worse fairly rapidly.
Good luck with your project!
Calvin
09-10-2006, 09:34 PM
Silver Mist
Riverhead
, New York
are the curtains in good shape I can usse them?
09-10-2006, 09:46 PM
1976 26' Argosy 26
St. Albert
, Alberta
Mildew and such
Hi Calvin,
Yup, some of the problem was at the water pump under the couch...as you can see in the above post photo. Some more water evidence infront of the fridge too, lots of it in the underlay...and getting the cushions out of there may have helped, but as we get further into it...well, there's more and more of the years and years of previous owners' clippings and layerings and screws and rivets and carpet pieces (found yellow shag carpet under the side cabinet!) and ancient pens and historic documents (someone's homework) and old pet leashes and PO fixups. Yup, this old puppy is getting a good shaking out!
Cheers!
09-10-2006, 09:50 PM
1976 26' Argosy 26
St. Albert
, Alberta
Curtains
Hi Bob,
The curtains are in ok shape, they are plastic lined on the back. They're not great though...they're yours if you want them. I'll take pictures tomorrow evening of close ups. They are on some kind of special track, a C-channel into which plastic tabs on the curtains slide into.
Cheers!
09-11-2006, 06:17 AM
Did someone get the stove
If no one has laid claim, I'll take the stove.
Paul Waddell
WDCU 1stVP (to be impeached)
09-11-2006, 05:17 PM
Silver Mist
Riverhead
, New York
I'll give them a try how can we exchange info, can you please PM me.
09-11-2006, 06:55 PM
1966 17' Caravel
Las Cruces
, New Mexico
I'm interested in the sink covers (The cutting boards with formica on top). Any chance you will be giving them away?
1966 Airstream Caravel
2006 Toyota Tacoma
