Old 05-28-2006, 07:00 PM   #1
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Thumbs up Found another Minuet 6.0
Call it insanity, but I am buying another Minuet 6.0 - a 1979 this time. I don't think I can miss at $1800. Outside and inside look pretty good, owner says all appliances work, water system checked out, AC blows cold.Needs some cleaning and polishing, probably tires, maybe brakes. My wife says to fix this one up and take it to the 2007 Rally as a sale item.I'll post more when I pick it up in two weeks.
Argonaut20 is offline   Reply With Quote
Old 05-28-2006, 07:29 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Cool! Now all you need is a 77 model.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-29-2006, 08:51 PM   #3
SnorkyII's Avatar
2004 25' Safari
Escondido , California
If your wife really makes you sell it, then let me know, my wife said I can buy a smaller trailer for my trip to Alaska. I would prefer a Minuet, but may have to settle for a 20ft Argosy.
SnorkyII is offline   Reply With Quote
Old 06-20-2006, 06:17 AM   #4
1977 24' Argosy 24
SW Florida , Florida
Images: 8
Argosy 20 vs. Minuet 6.0
What's the difference between the Argosy 20 and the Minuet 6.0?
Elisa - 76 Argosy 20 owner
Elisa is offline   Reply With Quote
Old 06-20-2006, 07:08 AM   #5
1978 Argosy Minuet 6.0 Metre
1977 Argosy Minuet 6.0 Metre
Tucson , Arizona
size difference
I believe the minuet is 6 inches narrower than the 20. It was only built 77-79. I believe there are several changes that made it lighter including a aluminum, styrofoam, aluminum sandwich floor instead of plywood. There are probably others.
I have a 77 & 78 looking for a 79.
cape_bob is offline   Reply With Quote
Old 06-23-2006, 08:35 PM   #6
Argonaut20's Avatar
1966 17' Caravel
The '79 is decorated quite differently from the '78 that I have. Anyone else have flowered patterns in the shower panels? Upholstered valances over the windows? The grey water tank is under the floor (or is missing...) and supposedly larger (15 gal vs 10 gal). The floor is plywood rather than the aluminum sandwich, but seems solid. This is a model with the front gaucho rather than the dining table. The paint is original and shines up nicely with a little elbow grease. Appliances work, but there are some plumbing issues and (likely) brake issues to deal with. I'll try to post some pics a bit later.
1966 Airstream Caravel
2006 Toyota Tacoma
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
A little treat for the Minuet owners. barbwire All Argosy Trailers 14 11-14-2002 09:25 PM
Minuet 6.0 History? ARGOSY79 All Argosy Trailers 2 10-06-2002 02:12 AM
