Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 05-19-2005, 08:55 AM   #1
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Originally Posted by Swanny
How do you approach getting on the roof of the AS with damaging it?Mitch
I use a padded ladder against either aginst the awning cover or against the eyebrow above the door. Once on the roof, step only on the rivet lines and there will be no damage. Stay off of the end caps; first, they will not bear your weight and second, you will slip and fall.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 05-19-2005, 11:02 AM   #2
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Skyliner corrosion
My Excella 500 has a Skyliner antennae
Before you re-install that Skyliner or a replacement be sure to do a careful inspection of the roof where it was attached. We have discovered that the base of the Skyliners can corrode the aluminum roof over a period of decades, especially in some environments. This causes leaks.
The corrosion is such that it is not readily apparent until you wire brush the roof to remove the weakened aluminum. See the thread "Dissimilar Metal Corrosion" for details and pictures.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline   Reply With Quote
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 09:41 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 04:25 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 08:02 PM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 04:57 PM
Antenna Drive Gear CO_Don Audio, Video & TV 0 02-06-2003 05:45 PM
