Old 09-24-2007, 04:13 PM   #1
Electrical connections getting hot
When I plug my argosy into the extension cord and run it to my house power, 110, both blugs get very hot. I have an adaptor that takes the cord of argosy from 3 large prongs to 3 small prongs so it fits standard extension cord. Does this make sense?
Is this an easy fix?
Thanks for any and all replies.
I'm chugging away on her. All I need now is an axle, new cushions, paint job and she's back to 100%...
wardster is offline   Reply With Quote
Old 09-24-2007, 04:22 PM   #2
richinny's Avatar
2011 34' Classic
you might be drawing more power than that cord can handle.
Ricky
Old 09-24-2007, 04:25 PM   #3
1984 31' Excella
Norfolk , Virginia
Images: 11
Electrical Connections
No absolutely not.
It works like this.
The cord connected to your Argosy has a 115 Volt AC 30 amp connector on it.
The standard house receptacle is for a 115 Volt AC 15 amp connector.
Thats all it will do.
If you draw any more current heating will result, possibly fire.
Not a good idea.
HOWEVER....
If you plug the trailer in and only run a light or two and allow the battery charger to charge the batteries/battery(battery switch turned on) there should be no problem.
The problem comes when you try to run the AC (12 to 15 amps or so) and or the microwave (20 amps or so).
The safe solution is to have a qualified person install a 115 Volt 30 amp RV recptacle, then you will have nothing to worry about.
Beginner
Beginner is offline   Reply With Quote
Old 09-24-2007, 04:30 PM   #4
richinny's Avatar
2011 34' Classic
p.s. you'll need a cord that can handle the distance and load too.
Ricky
Old 09-24-2007, 04:58 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
you can do the math for yourself here Voltage Drop Calculator JavaScript
john
you call them ferrets, i call them weasels.
Old 09-24-2007, 05:28 PM   #6
Old_Town's Avatar
North East , Texas
90 Degrees C
The wire in your cordset supplying the trailer is probably rated at 90 degrees C or 194 degrees F. The wire will withstand these temps without damage. If more than 15 amps are on the circuit for extended periods of time, it will heat up. With the a/c on my Safari draws about 13.5 amps. Microwaves seldom draw more than 15 amps. My fullsize 1000w at home draws 13 amps.
Warm plugs are nothing to get alarmed about. If they become to hot to handle, it's time to be concerned. The contact points are usually the source of most of the heat.
-Ty
Old_Town is offline   Reply With Quote
Old 09-24-2007, 05:30 PM   #7
jimmickle's Avatar
2000 31' Land Yacht
What gage is the extension cord, and how long? Twelve gage would be good. Fourteen gage minimum.
Jim Mickle
jimmickle is offline   Reply With Quote
Old 09-24-2007, 07:11 PM   #8
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
What's the load?
Originally Posted by wardster
When I plug my argosy into the extension cord and run it to my house power, 110, both blugs get very hot. ...
Are you running the air conditioner?
Tom
Old 09-25-2007, 07:13 AM   #9
Thanks gang.
Yes, I was running the a/c as it's hot down here. I have her in my driveway and left the windows cracked to keep it aried out. I went in yesterday and realized I had a mold problem. It was starting on almost every surface. So I had to spend a good amount of time cleaning it out, with A/C on.
Old 09-25-2007, 09:33 AM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
-Ty
Boy do I hope you live close to the fire house.
Yes he most likely will not melt the wire to the trailer but that same current is being drawn from the house and is most likely on a 20 amp braker. The house wiring is also getting hot and is not rated for 90 C.
Warn wiring is what starts Christmas fire.
2004 Excursion 4x4
Old 09-25-2007, 09:55 AM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Are you running it on a 15 amp outlet with a 15A-30A adapter? If that answer is 'yes' is it the outlet or extension cord getting hot or the trailer's heavy gauge cord?
BTW -- the compressor takes something around 20 amps at A/C startup. Repeated use at 15 amps causes the compressor to struggle and fail before long.
5 meter Langford Nahanni
Old 09-25-2007, 10:30 AM   #12
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
All conductors have some resistance to them and with our vintage trailers comes plugs with a goodly layer of oxidation on them. Even a new plug set will show heating but the thermal mass is enough to dissipate it. Older service plugs oxide layers keep a positive connection from happening and increases the resistance seen by carried current thus heating the metals which increases the oxidation levels and resistance. Letting the plugs get wet only accelerates the process, like maybe when camping or some other silliness.
One thing you can do is use 'automotive ignition wiring silicone dielectric gel' to keep oxygen and water away from the contact area, sold in tiny tubes or included with wiring sets. It's easy to polish the prongs and nearly impossible to clean the plug contacts so its best applied to a new plug. An extension cord with a heavy conductor size will also act as a heat sink, each heavy connected wire helping dissipate the contact area heat into the length of the cord while not producing much internal heat of its own instead of allowing the plug body to be the primary heat sink as its nicely insulated via slowly melting plastic...
Another issue is the relaxing of the cord-sockets contact grips spring tension through use, abuse, and overheating - unless the plug can be dissembled its non-serviceable so be gentle.
Old 09-25-2007, 10:50 AM   #13
I'm assuming yes to the 15 amp outlet. I have an adaptor that fits on the heavy gauge cord attached to the argosy. This adaptor allows me to plug into a regular extension cord. Where the adaptor and ext. cord meet is where it's getting hot. There was a little bit that started to melt too.
Old 09-25-2007, 10:59 AM   #14
Every time the thermostat tells the compressor to cool again the A/C tries to draw 21-22 amps thru the 15 amp outlet. It does pull lower current once it's running. Are you popping a breaker ever? The heat should tell you something -- saving the compressor -- priceless. Well, $2000....
I looked at an Overlander near Chicago whose PO ran the A/C in his driveway off a standard 15A plug. He burned out one A/C unit, replaced it and burned out the 2nd unit. He told me it just needed refrigerant ... . The A/C is the only reason your Argosy has a 30A plug. You should have an electrician put in a 30 amp circuit if you need to run the A/C in your driveway.
CG Cable Connections Denis4x4 Audio, Video & TV 1 09-18-2007 05:26 PM
LP Connections - US vs Canada campadk LP Gas, Piping, Tanks & Regulators 0 04-30-2007 10:15 AM
Tow Connections jcferguson Electrical - Systems, Generators, Batteries & Solar 1 02-19-2005 03:34 PM
TV connections Southern Gal Electrical - Systems, Generators, Batteries & Solar 10 07-17-2004 12:06 AM
